If you guys are hearing lifter or injector tick... you got super hearing. Or your radio isn't loud enough.
There's your free fix of the day. I got 184K and I'm not hearing crap.
Note I can only hear them if i pop the hood.
while driving? forget about it.
too much road noise.
I can only hear mine tap with the hood down, window down, stereo off. Starts faintly at 1200RPM then stops around 1800RPMish. Only in first gear, after that road noise takes over.
All thirydumbhundreds are horrible noisy crapboxes. Really though guys.. I don't hear my 3800. Maybe it's cause I bumped the pressure a smidge?
you should put a 3800 in it. your car will thank you
Well I'll describe how mine is setup. It was base... so I did the single exhaust to a single-to-dual Super 44 then bought a new valance. Made them come out both sides from the muffler. Then at first I had res cut... was way to raspy so I threw in a 24" glasspack. Sounds fairly decent now. Doesn't rasp nearly as bad. Nothing to awesome, but doesn't sound like total azz.
