Thread: Inet size
Results 1 to 4 of 4
  1. #1 Inet size
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    What is the supercharger inlet size on on a stock gen III m90?
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Inet size
  3. #3 Re: Inet size
    Oct 2008
    Calgary, Alberta
    I believe stock sc inlet is around 72mm (2.83") (a match to the zzp ported tb) . I am in the process of porting one to ~ 75-76mm (2.95") and zzp now ports their inlet to 78mm (3.07") to match their billet tb.
    Stock tb blade is 69mm (2.71")
  4. #4 Re: Inet size
    Jan 2009
    ny
    Thanks for the replies, so that means if I buy the ZZP Hv tb, the tb inlet will match the Sc inlet. Buying the Hv tb and having hone the sc inlet isn't something I want to do.
    Edit: Got an answer from ZZP, it does match.
  1. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  2. Rim size
    By Xorbex in forum General Tech Discussion
    Last Post: 11-04-2009, 01:41 PM
  3. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  4. stock size? PLEASE HELP on piping and 2.25 muffler size
    Last Post: 07-27-2008, 09:52 PM
  5. what size rim
    By blazedgp in forum Tires & Wheels
    Last Post: 02-20-2008, 01:49 PM
