hey guys, so the ss is up and running with the new genv and xp cam set up....no leaks or anything that i can see or hear/feel..
after i put everything back together i decided to test it out and noticed that it seemed to be breaking up even with the stock 3.8 pulley on the gen v. seemed to notice it mostly around the upper rpm range of second gear.
a few days later i put my intense 3.4 mps on the gen v (since i will be getting tuned eventually) i got on it once just to see if the problem was worse and sure enough it was. its breaking up all over the place in first gear cutting in and out, feels like a combination of missfiring and fuel cut... and yes i have been super gentle on the car and babying it until i can get it on the dyno and see whats going on....
i really dont think i should be running out of fuel, i am on my old tune still that i had with my rocker set up and 3.4, but i know anything is possible....i was also thinking maybe spark blow out, or a possible bad wire/coilpack/plug wire... id like to see some of your guys feed back and opinions as to what you think it may be.
did a scan when i had the 3.8 on when it was breaking up and got 0 kr and was around 15-16* timing but i was only around 4k rpms in 2nd gear
