Thread: Autolite 606's
Results 1 to 18 of 18
  1. #1 Autolite 606's
    SE Level Member black plague815's Avatar
    May 2011
    Illinois
    The guys on this forum werent joking about the autolite 606's, they are the best by far that Ive put into my 2000 GTP, abd Ive tried some of the high end plugs too. Thanks again GPforums
  2. #2 Re: Autolite 606's
    Omaha, NE
    You're welcome!
  3. #3 Re: Autolite 606's
    SE Level Member d8teen's Avatar
    Jul 2010
    Fl-Hollywood
    I will have to try those, all i was buying is that iridium stuff from ngk and bosh with two ends.
  4. #4 Re: Autolite 606's
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    do these take place of stock or is tis a colder plug
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  5. #5 Re: Autolite 606's
    stock heat range.
  6. #6 Re: Autolite 606's
    SE Level Member hklvette's Avatar
    Jun 2010
    Christiansburg, VA
    I use XP605s in mine instead of the copper cores. the L32 seems to approve.
    '05 silver GTP, '98 Cherokee, '78 M880, '70 M35A2
    "Drag racing is for fast cars. Autocross is for fast drivers."
  7. #7 Re: Autolite 606's
    how are they burning?
    Those are cooler than stock, have mods?
    and iridiums are fine, platinum is not.
    but copper is most ideal.
  8. #8 Re: Autolite 606's
    Old motors...old technology. They love copper plugs like they enjoy cold thermostats and high octane gas.
    Still works...even though people are goin' different routes.
  9. #9 Re: Autolite 606's
    Pennsylvania
    Except that it's a waste spark system that destroys copper plugs.
  10. #10 Re: Autolite 606's
    we're in the stupid charged section boss.
  11. #11 Re: Autolite 606's
    Quote Originally Posted by SlowNA06 View Post
    You keep your SLOWNA06 outta here
  12. #12 Re: Autolite 606's
    Pennsylvania
    Are you saying supercharged 3800's aren't waste spark?
  13. #13 Re: Autolite 606's
    nope
    Copper is a waste on N/A and only lasts 15k mi.
  14. #14 Re: Autolite 606's
    Basically it comes down to...welcome to modding. If you plan on it...get used to changing your 1.99 spark plugs every 2 or 3 oil changes. If not, then sure...spring for the Iridiums.
  15. #15 Re: Autolite 606's
    Pennsylvania
    nope
    Copper can still fail as much on S/C engines. It's simply not as much of a waste, since it can make use of the cooler properties of the copper unlike the N/A motor, which will simply lose 1-2mpg from copper.
  16. #16 Re: Autolite 606's
    Right...it can still fail, I agree.
    But at the rate you change them out...failure rate is slim to none.
  17. #17 Re: Autolite 606's
    Pennsylvania
    True. Change them at 15k, and you'll never have a problem. Personally, I'd still check/re-gap Iridiums at 50k regardless, if only to keep them from seizing to the engine, so there's that.
  18. #18 Re: Autolite 606's
    BAM.
    So everyone loves everyone...I should be a shrink.
  1. Gapping autolite 104's
    By Colossus in forum General Tech Discussion
    Last Post: 12-30-2009, 11:29 AM
  2. Autolite 103's
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2009, 05:26 PM
  3. Autolite 104s
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-16-2009, 09:43 PM
  4. Autolite 605's or 104's
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2008, 08:19 PM
  5. My autolite 104's are bad???
    Last Post: 07-03-2008, 03:30 PM
