Thread: head gasket?
Results 1 to 18 of 18
  1. #1 head gasket?
    Banned
    Jun 2011
    Pulled my spark plugs after about 500 miles since installing them...
    All the front plugs are nice and pretty.. Start on the rear,
    #2 the insulator is all brown and it was wet looking..#4 insulator is brown
    but does not look wet..#6 was as pretty as the front.
    Now there has been a bunch brown greasy crap i have been flushing from my radiator.. thought it might have been some stop leak from the previous owner....this brown crap is about the color of #2 and #4 plugs.
    but with #2 looking wet, it was kinda oily looking. would burning oil make the insulator brown? or could it just be the brown crap that is in the radiator and the wet look is from antifreeze?
    Guess i'm asking,...Blown head gasket or jacked up bottomend?
  2. #2 Re: head gasket?
    Grand Island, Nebraska
    Is there blue smoke coming out the back? or white for that matter?
  3. #3 Re: head gasket?
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    bad LIM gaskets?
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  4. #4 Re: head gasket?
    Banned
    Jun 2011
    LIM gaskets replaced 200 miles ago...
    No smoke what so ever...
  5. #5 Re: head gasket?
    did you mix a different coolant with your dexcool? do you have any misfires?
  6. #6 Re: head gasket?
    Banned
    Jun 2011
    no dexcool for awhile now. been running water to flush out the sludge.
    Yes i have miss fires at idle from cyl. #2, no codes for it though..
    like i said this motor dont smoke at all. has NO blowby. uses NO oil. oil is clean..
    i am confused?
  7. #7 Re: head gasket?
    You say you did plugs. How about wires and or cleaning the coil towers if they are gross?
    Headgasket is about one billion to one in these cars. I'd rule that our nearly from the start and confirm everything else in the universe first.
  8. #8 Re: head gasket?
    Banned
    Jun 2011
    did the plugs, wires, coil packs look new.
    gonna do another compression test..
  9. #9 Re: head gasket?
    I was gonna say maybe the valve seals are trashed...but then you said no blue smoke...
  10. #10 Re: head gasket?
    Banned
    Jun 2011
    i know no smoke...its confusing..
    compression test results
    dry
    1)105
    2)85
    3)100
    4)95
    5)100
    6)95
    wet (oil added)
    1)170
    2)170
    3)165
    4)150
    5)150
    6)150
    so now i am leaning toward sticky or worn compression rings..time to seafoam..
  11. #11 Re: head gasket?
    The rings aren't likely to be worn or sticky. Our rings are low pressure rings and they don't wear out like the avereage ring. That's why our motors live forever if maintained.
  12. #12 Re: head gasket?
    Banned
    Jun 2011
    what are you suggesting this could be then?
    broken rings? damaged piston? head issues?
  13. #13 Re: head gasket?
    Banned
    Jun 2011
    what is a good head gasket? just the standard felpro?
  14. #14 Re: head gasket?
    was that compression test cold?
    felpro's are decent gaskets.
  15. #15 Re: head gasket?
    Banned
    Jun 2011
    not cold...ran it down the highway, let it sit for about 15 minutes
    then compression checked it..
    i pulled it apart and had some pretty fat cracks in the heads
    between all the valves..some were hairline, but noticeable.
  16. #16 Re: head gasket?
    Cracks are typical.
    compression is not.
  17. #17 Re: head gasket?
    Banned
    Jun 2011
    yeah...took the heads off, turned em' upside down on a bench..
    filled the chambers around the valves with antifreeze.. went back to em a few hours later..all the antifreeze leaked out through the cracks on my rear head..front head had a little seepage..
    the cracks was causing my compression loss on a couple cylinders..
    is a crack about .045 typical? all the way through the seats and into the runners?
  18. #18 Re: head gasket?
    No.. 96-early98 heads were known to be prone to cracking, but typically it was only noticable when having the heads magged.
