I have a 97 GTP that I had to drop the engine cradle on this past weekend because a power steering pump bolt had broken off in the engine block and I had to remove it. Once I got everything back together, I noticed that when I turned the car on the ABS, Check Tire Pressure, and Air Bag lights come on and will not go off (The air bag light actually flashes a couple times on startup then stays on). This sound like wiring problem?
