Thread: ABS, Check Tire Pressure and Air Bag Lights On
Results 1 to 4 of 4
  1. #1 ABS, Check Tire Pressure and Air Bag Lights On
    Apr 2011
    Gainesville, FL
    I have a 97 GTP that I had to drop the engine cradle on this past weekend because a power steering pump bolt had broken off in the engine block and I had to remove it. Once I got everything back together, I noticed that when I turned the car on the ABS, Check Tire Pressure, and Air Bag lights come on and will not go off (The air bag light actually flashes a couple times on startup then stays on). This sound like wiring problem?
  2. #2 Re: ABS, Check Tire Pressure and Air Bag Lights On
    St. Louis
    Yep, sounds like an ABS sensor is not connected good at one of the wheel bearings. Not sure on the Air Bag light. May want to scan for codes on that one.
  3. #3 Re: ABS, Check Tire Pressure and Air Bag Lights On
    I'd add in checking the grounds at the lower trans bolt.
  4. #4 Re: ABS, Check Tire Pressure and Air Bag Lights On
    Apr 2011
    Gainesville, FL
    Ok, will check those. Is that a common ground for those three systems? How does the wiring run behind the engine for these? If it was just ABS and Tire Pressure, I would suspect the sensor near the wheel, but with the air bag on, I'm not sure.
  1. check tire pressure? After I cleaned by tb..
    By dougf in forum General Tech Discussion
    Last Post: 06-07-2013, 09:31 PM
  2. ABS and check tire pressure light on
    By GTP2188 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2010, 02:12 PM
  3. ABS and check tire pressure light on
    By GTP2188 in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2010, 07:00 PM
  4. Check Tire Pressure?
    By 04gpking85 in forum General Tech Discussion
    Last Post: 02-11-2009, 01:06 PM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
