Thread: Gen III Gen V Intercooler differences
Results 1 to 16 of 16
  1. #1 Gen III Gen V Intercooler differences
    GT Level Member ls1camino's Avatar
    Laurel, MD
    I have a 2000 GTP and I'm gathering parts to do a Gen V swap with an intercooler. There is an awesome deal on a nice Thrasher Gen III Intercooler/LIM. Will this work with a Gen V blower? I know the PCV routing is different, but I'm planning on running a "custom" PCV setup anyway.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Gen III Gen V Intercooler differences
    Portland Oregon
    The Gen V outlet is larger than the Gen 3. It's also further towards the passenger side of the car. It wouldn't be worth it to try getting the Gen 3 IC core.
  3. #3 Re: Gen III Gen V Intercooler differences
    Minnesota
    I honestly don't think it is going to make that much of a difference. Two guys on our local forum are running Gen Vs on Gen 3 cores. One of the guys is the white Regal that made 333Whp on a Gen V/Gen 3 core with E85. That number is debatable but has to be semi close.
  4. #4 Re: Gen III Gen V Intercooler differences
    Vancouver, WA
    Quote Originally Posted by Pure2sin View Post
    Is he the guy on clubgp that everyone was freaking out on? Now that I know he has a Gen 3 core I don't believe it either.
    Slowest 'Cooled Gen V ever
  5. #5 Re: Gen III Gen V Intercooler differences
    Quincy, Mass
    No more GP 04 Impala SS Indy:
  6. #6 Re: Gen III Gen V Intercooler differences
    Gen V gasket on a Gen 3 IC core
  7. #7 Re: Gen III Gen V Intercooler differences
    Minnesota
    That image is misleading because its a stock gasket. That image is correct if you don't take the H-bar out of the Gen V. If you remove the H-bar from the Gen V and use a non stock gasket you will be ok.
  8. #8 Re: Gen III Gen V Intercooler differences
    And a point I was about to make.
    ZZP's isn't the only IC out there. You can open up a ZZP a bit and cover some of that inch, as well has have material for the Gen V front edge to sit on and seal with. However the front edge of the IC must be considered. ZZP's IC's tend to be huge in comparison to some of the early WBS and Thrasher designs. Take a very close look at the bolt hole in the bottom left of both my pic and the below Thrasher pic. See where the core opening of the Gen V sits. It's going to be close or impossible to seal the Gen V SC to the IC core if the IC core doesn't have material under the edge of the Gen V SC.
    This one is a Thrasher,
    My initial thought is that if you laid that Gen V gasket on the IC, this left edge is potentially going to show sunlight.
    Now compare those bolt holes with the ZZP cores. There is a ton more material that extends past the bolt hole in question.
    You might ask, "Bill why do you know this?" I bought a "Gen V" core from someone and it is the core in the picture. It's actually a Gen 3 core. I then had it modified to be a Gen V, because there wasn't enough material on the front edge to seal as well as I'd like.
    Here's another view of the same issue. A Gen V gasket laid over an Gen 3 gasket.
  9. #9 Re: Gen III Gen V Intercooler differences
    Waukesha, WI
    so it will work, just not as efficent?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  10. #10 Re: Gen III Gen V Intercooler differences
    As long as the Gen 3 core is big enough for the Gen V to fit on and not leak. Yeah, it'll fit. You'll be blocking an inch of air at the front end (largest end).
  11. #11 Re: Gen III Gen V Intercooler differences
    GT Level Member RegalGS98s's Avatar
    NJ
    And so a L67 LIM will work with a Gen V blower then? It just needs to be machined a little, which most usually open the top up anyways? I thought the bolt holes were different between the 2 blowers. Were there also improvements to the dead spots I hear of in the LIM?
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  12. #12 Re: Gen III Gen V Intercooler differences
    See how that gasket is perfect except at the opening. That's the amount of material you would take off the LIM, if you had a Gen V IC. Since you are aiming to run a Gen 3 IC...it likely isn't worth your time to open it up. Dead spots? There's no difference I've seen except the newer L32 LIM's have no recessed area for coolant o-rings.
  13. #13 Re: Gen III Gen V Intercooler differences
    NJ
    I have a Gen 3 IC, but I wasn't thinking of using it with a Gen V M90. It's a little over 2 inching thick, but the core is only the size of the Gen III outlet (don't know what IC it is, it came with the GTP when I got it). When I get to the M112, I figure it would be way too small. Kuntzie in his turbo build thread where he's using a Holden intake, I remember him talking about dead spots in the LIM of these engines. I just checked his thread and he said there's dead spots in the LIM of the L26/L36. I'd assume the L32/L67 LIM would have similar dead spots also.
  14. #14 Re: Gen III Gen V Intercooler differences
    zzp did a test on it and if you use the genIII core with the genV blower you only lose like 2-3 whp...
    let me find that article if i can...
    but just for the record Im running the genV on my gen III core and its amazing... like real amazing...
  15. #15 Re: Gen III Gen V Intercooler differences
    Vancouver, WA
    Why not just do it right?
  16. #16 Re: Gen III Gen V Intercooler differences
    Quote Originally Posted by footballplaya3k View Post
    your saying having a GenV on a gen III is wrong?
  1. l36/l26 differences
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2011, 09:20 AM
  2. Differences in blocks?
    By PurpleGuy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2011, 11:20 AM
  3. the differences
    By noom14921992 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2011, 04:00 PM
  4. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  5. GT/GTP MAF differences?
    By pontiackid in forum General Tech Discussion
    Last Post: 05-24-2009, 07:47 AM
