Thread: Broken plastic hose, vacuum leak, help needed!
Results 1 to 9 of 9
  1. #1 Broken plastic hose, vacuum leak, help needed!
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Hey guys! So yeah my engine started making a weird noise lately, coming from the driver side. I checked the components and found a broken plastic hose. It is located under the throttle body and the intake on the side part of the vacuum system. Its a black plastic component with two exits, one that is connected to some sort of sensor which is red and blue. It is next to that grey electrical cylinder component (sorry I don't know the name)
    The check engine light came on and I'm almost sure it is a vacuum leak. Can someone please help me find the name of that component. I just don't want to go to GM and pay a crazy price for something I might be able to find used. Thanks!
    I will post pictures later today.
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  2. #2 Re: Broken plastic hose, vacuum leak, help needed!
    Dec 2010
    Montreal, Canada
    Here is a picture, best I could find...Yes, I know, my engine bay is spanking clean :P
  3. #3 Re: Broken plastic hose, vacuum leak, help needed!
    You'll have to get a better pic i think i know what your talking about but im not sure without a closer pic.
  4. #4 Re: Broken plastic hose, vacuum leak, help needed!
    Dec 2010
    Montreal, Canada
    There you go and thanks for your time
  5. #5 Re: Broken plastic hose, vacuum leak, help needed!
    Quincy, Mass
    thats your evap hose.
    No more GP 04 Impala SS Indy:
  6. #6 Re: Broken plastic hose, vacuum leak, help needed!
    Quincy, Mass
    so if the nipple broke off of the evap sensor you can replace the evap sensor and be all set.
  7. #7 Re: Broken plastic hose, vacuum leak, help needed!
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by Swiggles View Post
    Is there a specific part name because I can't find it anywhere...Evap canister maybe?
  8. #8 Re: Broken plastic hose, vacuum leak, help needed!
    Quincy, Mass
    on rockauto.com its under emissions and is called a Vapor Canister Solenoid
  9. #9 Re: Broken plastic hose, vacuum leak, help needed!
    Dec 2010
    Montreal, Canada
    Yep, that's what I was looking at hehe! Thanks a lot!
  1. Missing HVAC Vacuum Hose??
    By brandonl2000 in forum General Tech Discussion
    Last Post: 01-15-2011, 04:39 PM
  2. H@lp Fast Please - Rubber/Plastic Cushion for Idler PULLEY Broken
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 04:22 PM
  3. Vacuum hose
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 07:01 AM
  4. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
