Thread: Help! Stripped supercharger plug
Results 1 to 12 of 12
  1. #1 Re: Help! Stripped supercharger plug
    Portland Oregon
    If you take the bolts off the snout you can take the whole snout off to change the oil. If you do this on the car it'll make a stinky mess. I'd recommend removing the blower for this method
  2. #2 Re: Help! Stripped supercharger plug
    Donating Users
    South Deerfield, MA
    You can drill a hole through the middle of the plug and use an easy out to take it out. You will want to remove the snout to make sure you don't get any metal shavings in the supercharger oil.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. Stripped stud with lug still attached
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 08-29-2012, 04:31 PM
  2. Plastic oil pan - Plug stripped - Suggestions
    By drmurdoc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-12-2010, 09:34 PM
  3. Transmissoin pan bolt stripped
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-06-2008, 10:39 PM
  4. Alternative fix for stripped threads
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2008, 05:03 PM
  5. Supercharger Fill Hole Bolt Stripped
    Last Post: 01-18-2008, 06:20 AM
