Thread: ned some advice =(
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: ned some advice =(
    GTX Level Member Juanmiguel's Avatar
    Mexico
    well I decided to leave it like that for now. There doesn't seem to be a single unanimous reason for changing it for now. I also agree that the best option would be to just go ahead and change it, but there are some opinions that say it will work.
    I'll try it like that, I guess it'll kind of serve as a proof of concept for some of us. If it does create issues, we'll just go ahead and replace it.
    We turned it on earlier today and give it gas a couple of times and there didn't seem to be any issues so far.
    I still need to try it at the track once the tune is completed. If anything goes wrong, I'll post it back here.
    thanks all.
  2. #22 Re: ned some advice =(
    Feb 2008
    San Diego, CA
    One question not yet asked...
    Why the hell would you turn it over if you thought you might have dropped a piece of hardware into the cylinder?
  3. #23 Re: ned some advice =(
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by agrazela View Post
    I was wondering the same thing. And Juan, if you were just trying to run the engine stock, you might make out alright. But where you want to increase it's performance, leaving it as is, is a bad idea. I can see pre detonation and because of those shavings, engine miss balance. The engine balance may only be minimal, but it has to be there since there's missing material from the piston.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  4. #24 Re: ned some advice =(
    Mexico
    Well you may be right. As I said, the engine is back together and I'll just have to find out. If it detonates or breaks I'll just go ahead and fix whatever is necessary.
  5. #25 Re: ned some advice =(
    Mexico
    I picked up the gtp at the shop earlier. It pulls hard and there are no issues so far. I still have to scan and tune it.
    Just one question. Is the ic pump suposed to get hot?
  1. New and looking for advice
    By andrewwg in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 06:06 PM
  2. Need some advice on car
    By picghaw in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 08:29 AM
  3. Need some advice
    By lhcombs in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 01:21 AM
  4. CAI advice
    By tayl5645 in forum General Tech Discussion
    Last Post: 07-16-2010, 10:08 AM
  5. Need some advice
    By 40mphGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2010, 08:49 PM
