Thread: ned some advice =(
Results 1 to 20 of 25
  1. #1 ned some advice =(
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So I installed a ported SC and the SSIC core today. But I probably just did the most stupid thing I've done this year...
    I was putting back the fuel rail with the injector spacers, but to do this you have to take out the factory bolts that hold down the rail to the LIM. While I was doing this, the bolt that's closest to cylinder 6 fell into the injector hole and into the cylinder.....
    I turned it on for a couple of seconds just to make sure it went all the way in, of course there it was, the rattle.
    Right now I plan to try and pull it out using one of those magnet reach things through the spark plug hole, I think it's possible since those studs have no head. Although it may take a lot of patience.
    Do you guys think it's worth a try? What else could I try to pull it out? I'm trying to find out what options I have before I go and pull the head out.
  2. #2 Re: ned some advice =(
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you turned over the motor? Pray id didnt mash your pistons or valves
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: ned some advice =(
    Mexico
    it was really quick as soon as it rattled, it shut it off.
  4. #4 Re: ned some advice =(
    Hagerstown,Md
    You may get lucky. I doubt it though. Id imagine it beat up the piston and valves.
  5. #5 Re: ned some advice =(
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    damn
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  6. #6 Re: ned some advice =(
    SWPA
    Quote Originally Posted by Juanmiguel View Post
    Once it rattled it was too late.
  7. #7 Re: ned some advice =(
    Mexico
    yeah i think it's pretty much busted, the magnet reacher thing didn't seem to be grabbing anything inside the cylinder, probably the stud is stuck somewhere inside. Gonna tow it later and let the mechanic fix it and finish doing the IC install.
  8. #8 Re: ned some advice =(
    Mexico
    Ok so the head is off and this is what we found:
    The question now is I should replace this piston or not. Nothing else has any marks in this cylinder.
    You guys think it will work fine if I leave it like this?
  9. #9 Re: ned some advice =(
    That's a shame...I would have yanked the head before even ATTEMPTING to turn it over...
  10. #10 Re: ned some advice =(
    Mexico
    yeah it sux, but anyway. the mechanic says we can leave it like that, what do you think?
  11. #11 Re: ned some advice =(
    Jersey
    run it until it blows up
    16' wrx sti- stock
  12. #12 Re: ned some advice =(
    I actually don't know Juan...I can't see pics at work.
    Quote Originally Posted by 99prixgt View Post
    I'm with this guy...its just a GP...fill it with 60 weight straight oil and trade it in for that SRT8
  13. #13 Re: ned some advice =(
    St. Louis
    Did you find the missing stud? Is the piston cracked at all? I'd clean it off real good and see. If not then I'd put it back together. How's the valves look for that cylinder?
    You got lucky. When I "lost" a bolt during a LIM job it shattered my piston on #1 to the point where all that was left was the rod and wrist pin beating the cylinder wall up. Yea, stupid I know but sh*t happens.
    In my defense I thought I'd seen the bolt jammed down low and didn't think it made it where it did. Had I known I would have pulled my head before starting it at all. The 1K+ rpms it turns on startup is enough to destroy a piston in .000000002 seconds
  14. #14 Re: ned some advice =(
    Mexico
    Yeah we found the stud, it was a bit crushed, but that's about it. The piston is not cracked at all, the head and valves are intact.
    Thanks for the input guys I just wanted a second opinion. I'll run it like that. Now I may want to get those heads ported now that one of them is off. But i'll just create a new thread about it hehe.
  15. #15 Re: ned some advice =(
    Minnesota
    That or while you are fixing that piston you could put a cam in?
  16. #16 Re: ned some advice =(
    Mexico
    Quote Originally Posted by Pure2sin View Post
    Already have one
  17. #17 Re: ned some advice =(
    I'd swap the piston out from the bottom.
    Drop the cradle...turn it over by hand...remove oil pan...etc...etccc....etccccccccc
  18. #18 Re: ned some advice =(
    If the piston looks like that the head has to have some impression too it was certinaly compressed to leave the thread marks in the piston. No way in hell I'd leave that!!!
  19. #19 Re: ned some advice =(
    Mexico
    You can see something on the head, but just barely, not impressed at all. It looks more like a stain. the form of the head remains completely unchanged as it's made from a harder material.
  20. #20 Re: ned some advice =(
    GT Level Member RegalGS98s's Avatar
    NJ
    ^this That piston looks like it will cause pre detonation. I wouldn't think of continuing to run that.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  1. New and looking for advice
    By andrewwg in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 06:06 PM
  2. Need some advice on car
    By picghaw in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 08:29 AM
  3. Need some advice
    By lhcombs in forum Introductions/Noob Questions
    Last Post: 07-21-2010, 01:21 AM
  4. CAI advice
    By tayl5645 in forum General Tech Discussion
    Last Post: 07-16-2010, 10:08 AM
  5. Need some advice
    By 40mphGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2010, 08:49 PM
