Thread: Odd Electrical question
Results 1 to 5 of 5
  1. #1 Re: Odd Electrical question
    Florida
    the PCM isnt related to the voltage regulator in the alternator. the PCM is the Power Control Module. it controls all the spark, fuel, and other settings that allow the car to run.
    to check the voltage regulator get a volt meter and first test the battery with the car off so you know the voltage out put. then start the car and check it again. if it is changing more then one volt then you have a prob out put should be about 13.5 volt IIRC. anything below this could cause a problem light you are describing
  2. #2 Re: Odd Electrical question
    SE Level Member 1fastgtp's Avatar
    Jun 2011
    Lewiston
    Quote Originally Posted by Z34Phoenix View Post
    too check the voltage regulator get a volt meter and first test the battery with the car off so you know the voltage out put. then start the car and check it again. if it is changing more then one volt then you have a prob out put should be about 13.5 volt IIRC. anything below this could cause a problem light you are describing.
    what he said
    2000 Grand Prix GTP: Modifications: SLP catback exhaust-SLP Headers- 180 Termostat- wizaired cold air intake-PRJ 10.4mm wires- autolite 104's- zzp tune- full size intercooler- vs cam- 3.0" pulley ETC. Fastest Grocery Gitter in town
  3. #3 Re: Odd Electrical question
    Jul 2010
    canada
    okay thanks for the reply all I didn't know the regulator was in the alternator so pulled the alternator its new but going to get it tested anyway
    along with my odd electrical question hooked up my buddy's scanner and while driving the scanner would disconnect????
    any ideas? there? it runs funky at that moment too
    the power wire for the computer does it need something specific? other than constant 12 volts? I connected it into the lighter circuit think that might be my problem? open to ideas here....
    gives me a po118 engine coolant temp circuit high input ....Does this mean it runs too hot ? thermostat bad? temp affecting the running?
    and po443 evaporative emission system purge control valve circuit ...Am i right this is the sensor switch thing by the BBV valve?
    I don't have this connected to anything can i lie to it to make the code go away?
  4. #4 Re: Odd Electrical question
    Jul 2010
    canada
    Alrightie alternator checks out as okay.......
    battery is good.............hmmmmm?
    guess its a wiring thing oh boy
  1. Need some electrical help
    By Green97GTP in forum General Tech Discussion
    Last Post: 08-17-2010, 07:28 PM
  2. Electrical Question
    By Kenny75k in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2010, 07:46 PM
  3. Electrical!!!! HELP
    By gtpman in forum General Tech Discussion
    Last Post: 11-08-2009, 06:42 PM
  4. power window slash electrical question
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 06-22-2008, 09:25 PM
  5. Electrical (HELP)
    By tooez in forum General Tech Discussion
    Last Post: 05-24-2008, 07:28 PM
