Thread: Loud rattling noise coming from belt area
Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
  1. #41 Re: Loud rattling noise coming from belt area
    Apr 2011
    Gainesville, FL
    The coolant elbow is new and not leaking. Have checked to make sure its not leaking. When I had the water pump off a couple of weeks ago, it looked fine. The gasket was cracked and I just tried to make do and RTV it. Coolant does not appear to be getting on the belt. The weep hole is right under and behind the pulley right? Coolant does not seem to be coming from that area.
  2. #42 Re: Loud rattling noise coming from belt area
    yes, the weep hole is on the under side of the pulley shaft, behind the pulley, you can stick a mirror and a flashlight under the pulley to see if its wet or rusted looking, if you cant feel it with your finger.
  1. Loud pulley rattling... help!
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2010, 03:42 PM
  2. Rattling/Knocking Coming from Pulley/Belt Area
    By pc305577 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2009, 09:32 PM
  3. weird noise from supercharger/belt area
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 07-06-2009, 02:40 AM
  4. Loud Rattling Noise
    By Dangerous313KidInAPrix in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 05:18 PM
  5. Loud Clunking coming from rear left
    By adidasdude1061 in forum Brakes/Suspension/Chassis
    Last Post: 07-07-2008, 10:16 PM
