Dex cool gums up if it isn't routinely changed, which is what you are seeing as "mud". Dex cool is perfectly fine to use and is highly reccomended by GM, but requires changing annualy if not more frequently.
Flush it with water.
Fill it 50/50 with dex.
Change it at the intervals recommended on the bottle, or before.
No need for an annual flush, though there's nothing wrong with it if you've got the money and time to burn.
Videos of how to do a coolant flush should be pretty readily available online... too lazy to find you some (sorry).
The problem is that once the radiator is sludged its hard to get clean. I always ditch dexcool and go with traditional green coolant. It doesnt gum up and cause sludge. Just pers pref. Ive seen the amount of damage dexcool can cause when left un checked.
OK. But you're still going to end up sludge. Switch to green and no sludge
