anyone know what this is for and what its supposed to be plugged into?
Nope no cels, the abs sensor is plugged in at the wheel hub, that connector is zip tied to the steering column I looked for somthing missing a plug but don't see it.
O2's are square and have four pins. Signal, ground/ref, heater +/-.
Fordman does win the panda bear this time.
Ya know..if you posted your year and model it would also help folks.![]()
Wheel speed sensor?
That looks to be the connector for the Magnasteer (variable assist steering). If you take a look at the harness that runs over the top of your trans (near where the shifter cable attaches) you should find the other end.
