Thread: What MODS Do I NEED For A 3.5 Pulley?????
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: What MODS Do I NEED For A 3.5 Pulley?????
    May 2011
    wisconsin
    So.... I should run a 3.6 pulley with headers, cold air intake, 180tstat, and to much hate on the plugs so im still in need of what ones I should use...
  2. #22 Re: What MODS Do I NEED For A 3.5 Pulley?????
    Pennsylvania
    Quote Originally Posted by szalajka05 View Post
    With a 3.6 pulley, you don't have a racecar. Don't bother with the thermostat.
    The cold air intake is unnecessary, it is easier and ~$200 cheaper to just strap a 9" cone on your maf - it'll make the same power. I'd say to try copper (to keep it cheap) 605's and see if you knock. If you knock or they foul, go colder. Don't forget a tune - every change of pulley requires a tune to be done right. You're dead on about the headers; you'll need them. Oh, and just to make sure you know, spark plugs should be changed before/ when the pulley is changed.
  3. #23 Re: What MODS Do I NEED For A 3.5 Pulley?????
    Short answer:
    no one knows till you try it.
    Long answer: click link in my sig.
  4. #24 Re: What MODS Do I NEED For A 3.5 Pulley?????
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    http://www.wbodystore.com/grandprix/...-run-a-23.html
    and/or headers.
    and always scan.
    if you have 04+, 3.6 p.
  5. #25 Re: What MODS Do I NEED For A 3.5 Pulley?????
    I kinda dislike the "what do I need for X part" thread and I'm sorry but had skipped your thread until now. I do have info to add.
    Dropping the tstat temps can help, but they don't always. A 180 is all that should be needed IMO. The bigger issue for temp is flow. Without coolant flow you can't help the engine drop temp. Anyone who has taken the end cap coolant cover off the LIM will know what I'm talking about. I recently posted a thread "how to mod a LIM", I feel it's a good read to understand the flow issue. With a rippin motor pushing down well over 400hp at the crank, I ran a 180 w/o a need for a 160. Thought never crossed my mind. (cammed/heads/rockers/pretty much one of everything). although changing the temp of the tstat and other things are pretty worthless in traffic if your fan settings haven't been changed to reflect the tstat changes.
    Another thing that I'd like to mention is ...don't be like many of us. Try not to think in terms of what's the smallest pulley you can run and then go to mods for that. With tuning and timing can come more power than dropping a pulley.
  6. #26 Re: What MODS Do I NEED For A 3.5 Pulley?????
    Quote Originally Posted by Xanthous View Post
    and/or headers.
    and always scan.
    I want pictures of your car in the avatar....Is it a Nismo Z? :fwap:
  1. 3.5" pulley mods?
    By Thexissilent in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2010, 11:51 PM
  2. What pulley size with these mods?
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2010, 10:25 AM
  3. could i run a 3.4 pulley with these mods?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 03:17 PM
  4. supporting mods for a 3.4 s/c pulley
    By BADAZGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 10:12 PM
  5. 3.5 Pulley WITH supporting mods
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 11:41 AM
