You have a baby cam.
And need a stronger valvetrain.
Get at it.
You'll make 30+ more WHP easy.
nick you forget to add injectors and a better tune to your list
Ok...so...50 more horse? LOL
And a smaller pulley.
I'm just saying.
I have an XP cam with 105# springs. You're telling me to change out my cam to a bigger one, which would require headwork, springs, a full tear down of the motor to the shortblock, and other supporting mods to maybe make 30whp more.
At the end of all that effort I still have a horribly inefficient blower and make less than what the TVS will without going through all that hassle.
whats the exhaust on this car since it hasnt been mentioned
Best I can find right now. Thats on a 3.25 pulley stock l67 injectors 12.3 afr with a lean out issue and yes injector drop off. so I droped 2-3 degrees of timing to be safe.I was trying to figure out, and pulled my 60's out to see if they were the issue(I was runing e85 about 8 months ago). If your really interested I have over 200 scans on my home CP im at work. Anyways heres the car and mod list http://www.grandprixforums.net/green...-gt-42587.html oh and on a 3.25 I run 10ish PSI depending on temp
Probably headers.
But jesus...you'll gain 30 horse from just headwork.
Your not looking at the big picture Flakey...ported heads/bigger cam/injectors/pulley/retune...now your looking at over 50 horse. Now your probably past your TVS swap...with the same "crappy" Eaton.
Then...this whole thread is boring...just like stock heads and an XP.
i think this is a LULZ moment?
My car has gone 12's on all season tires full weight street trim on 93 pump gas. I also made over 300whp using the same recipe...
People are real quick to attack my methodology...
