Thread: noise coming from the supercharger??? (video)
Results 1 to 8 of 8
  1. #1 noise coming from the supercharger??? (video)
    Donating Users
    Akron, PA
    It sounds like its coming right from the supercharger, reason to buy a ported gen 3??
    YouTube - 3800 SC Noise
  2. #2 Re: noise coming from the supercharger??? (video)
  3. #3 Re: noise coming from the supercharger??? (video)
    I live here. TLSheff's Avatar
    grindy rocky noise but doesn't sound like the typical coupler... sounds like a bearing is going out or possibly a rough point on the rotors rubbing the case. During the rev up it only gets faster so its bad but you really need a mechanics stethoscope to determine if its from the snout (needle bearings or coupler) or from the case itself (rotor bearings, rotors rubbing)
    could be fixable without having to order a whole new supercharger
  4. #4 Re: noise coming from the supercharger??? (video)
    Donating Users
    Akron, PA
    tumbling rocks? grinding? groaning? what is it doing?
    it sounds like a 2 stroke dirt bike engine if that helps describe the noise
    to be completely honest i was planning on porting the gen 3 but I can always get a used gen 5 blower from zzp for 500 bucks + TB adapter plate
  5. #5 Re: noise coming from the supercharger??? (video)
    Donating Users
    Akron, PA
    When the car is at idle and the bypass valve is held shut, the noise gets quiet but when open in vacuum the noise comes back???
  6. #6 Re: noise coming from the supercharger??? (video)
    remove the s/c belt and turn the pulley back and forth like snap it, and feel for play in the pulley, if so you at least know you need a coupler.
  7. #7 Re: noise coming from the supercharger??? (video)
    Donating Users
    Akron, PA
    when the bypass valve is held shut there is play in pulley but after letting go it feels more firm (not sure if thats the word im looking for)
  8. #8 Re: noise coming from the supercharger??? (video)
    SE Level Member vsl67's Avatar
    Australia
    YouTube - Eaton m90 supercharger rattle no 2 it sounds like rotor pack bearings
  1. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  2. Whining noise coming from alternator maybe?
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-28-2010, 11:50 PM
  3. Weird noise coming from my engine bay *with video's*
    By nawarkk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2010, 01:32 AM
  4. odd noise coming from front wheels
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 04-15-2009, 09:32 PM
  5. weird noise coming from engine
    By q1w2e3r4t5 in forum General Tech Discussion
    Last Post: 04-02-2009, 09:59 PM
