Thread: Computer boost gage
Results 1 to 5 of 5
  1. #1 Computer boost gage
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    I am a proud new owner of a 02 grand prix gtp, i just fixed the lights behind the computer but the boost gage says i have no boost.... ever. Is there a connection somewhere that could be bad? any suggestions are greatly appreciated
  2. #2 Re: Computer boost gage
    HUDSON
    A good thing to do would be to install a manual boost gauge to double check that you are actually NOT boosting. You can use a vacuum/PSI diagnostic gauge if you have one since it reads vacuum and PSI. You just need a long hose so you can view it from the driver seat while drivng so you can watch the gauge under WOT.
    I had a similat problem as you described, I found that the little filter on the end on the BBV solenoid (located in front of BBV vavle) was deterierated and clogged the port it was on. I simply cleaned the end and installed a litttle vacuum 90degree fitting on the end to keep dirt out. Now it boooosssttsssss.
  3. #3 Re: Computer boost gage
    Topeka, KS
    Check the green wire on the plug for the MAP sensor. IF it is dammaged or loose on the plug it will not register boost.
  4. #4 Re: Computer boost gage
    Grand Rapids, MI
    and keep in mind the stock boost gauge only works when you are at a certain speed and certain throttle position. it will not read boost just with regular driving.
    i thought the same thing when i got the gtp. then i stepped on it and it went UP UP UP.
    also, on the interstate in 4th gear, give it some throttle without changing gears you'll see it then, too.
  5. #5 Re: Computer boost gage
    Houston
    Quote Originally Posted by brandonl2000 View Post
    and keep in mind the stock boost gauge only works when you are at a certain throttle position..
    fixt brudda
  1. New Gage cluster
    By monsterjam5000 in forum General Tech Discussion
    Last Post: 09-27-2010, 06:50 PM
  2. 99 gt fuel gage prob!!
    By lmilhorn in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2010, 03:59 PM
  3. Weird temp gage problem
    By jokyfo in forum General Tech Discussion
    Last Post: 02-02-2010, 05:06 PM
  4. RPM gage stops while driving
    By nirahlee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2008, 04:50 PM
