So I have your standard 3.4 setup - Headers, 1.9 rockers, 180* stat, 104 plugs, cold air intake, and an Overkill PCM. The car runs great and pulls pretty hard throughout the RPM range. I've noticed lately that I am getting spikes of KR at random rpms/speeds. It will stay at 0, and remain at 0 when I ease into the throttle creating more boost. However, when I stab the throttle or go WOT, I will get random blips/spikes of KR upwards to 6*, then it will fluctuate back down to 0 (or less than 1*). I know that my front sway bar is shot, as I car hear clunking in the steering and sometimes a vibration from the engine when I shift gears.. My stock motor & trans mount also need to be replaced. So could this be false knock? Should I be concerned? Next week I am install a GMPP handling kit and new solid rubber mounts. Hopefully then the knock will go away then?
