Thread: selliott turbo gp
Page 30 of 40 FirstFirst ... 202829303132 ... LastLast
Results 581 to 600 of 785
  1. #581 Re: selliott turbo gp
    hangover park IL
    Find the tsb for metripack "fretting" issue....its why the metripack GT series (these have purple plastic on the connector body) are silver plated....the tin flashed terminals accelerate fretting.
    I've seen melted fuel pump module connectors on vehicles with less than 30000 miles. You do not make major changes to a whole production series of cars and vehicles to put in more expensive and nearly double the size terminals to fix an issue that is only found on out of warranty vehicles. Bean counters would only allow that kind of expenditure if it was a common issue on brand new vehicles under warranty which it was....
    ~James~ Psychotic Gearhead
  2. #582 Re: selliott turbo gp
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Turbocharged400sbc View Post
    14 amps...... but it's also sort of telling that all of the updates and all of the newer Vehicles use the flat 4 wire Metra pack 280 connectors for all fuel system units..... this kind of sort of tells you that even GM noticed that the 150 suck
    Holy shoot! I was looking at the wrong gm 4pin the whole time! Wow. You're not kidding about that being underpowered! I will definitely look into that when I upgrade my fuel pump. GM never ceases to amaze me....
  3. #583 Re: selliott turbo gp
    Aug 2017
    Raytown, MO
    Thanks Turbocharged! I learn something new about how GM pinches penny's all the time... lol I'm definitely looking into upgrading when I go with a larger pump....
  4. #584 Re: selliott turbo gp
    I break stuff selliott's Avatar
    Kansas City
    Thanks guys for your help, I will switch it over to the newer design immediately
  5. #585 Re: selliott turbo gp
    hangover park IL
    Go self fornicate
  6. #586 Re: selliott turbo gp
    Kansas City
    Go self fornicate
    Hello to you as well James, I hope all is well.
    I also realized that awhile back I had added zzp's alternator booster which most likely contributed to my problem and has now been removed and the external wires to the fuel pump are much cooler. Yup that was stupid
  7. #587 Re: selliott turbo gp
    Kansas City
    As far as the new cannister goes is one brand better than another? I see a wide range of prices I don't need the fuel pump I'm primary concerned if one manufacturer makes a better plug than another.
  8. #588 Re: selliott turbo gp
    Antioch, IL
    They all come with plugs you have to crimp on, the cheap ass canisters the fuel level sensor takes a **** the first year.
    2009 Challenger SRT8
    Expert at being gay.
  9. #589 Re: selliott turbo gp
    Kansas City
    The AC Delco one is $423.99....hell no
  10. #590 Re: selliott turbo gp
    Antioch, IL
    Just buy the plug/harness
  11. #591 Re: selliott turbo gp
    Kansas City
    From where?
  12. #592 Re: selliott turbo gp
    Antioch, IL
    ra or ebay
  13. #593 Re: selliott turbo gp
    Aug 2017
    Raytown, MO
    Quote Originally Posted by ItHurtz View Post
    You need the canister for the other end of the plug... lol
  14. #594 Re: selliott turbo gp
    Antioch, IL
    plug comes off the canister, replaceable
    20161224_195840 by Corey S, on Flickr
  15. #595 Re: selliott turbo gp
    Aug 2017
    Raytown, MO
    I've never seen a part number for the canister side and it'd be a gable to find one in the junkyard. If you have a part source, you would be my new best friend!
  16. #596 Re: selliott turbo gp
    Kansas City
    I have 2 cannisters but both have the old O2 style square plug. I ordered a new cannister its supposed to be here tomorrow. So it should be ready for Monday shenanigans. And if it burns to the ground I'll be one step closer to supercharged LT4 fun.
  17. #597 Re: selliott turbo gp
    hangover park IL
    Increasing voltage isn't hurting. If anything it drops the current draw on most inductive circuits and most resistive loads.
    I just drill a hole and run wires directly in with our TV ceiling it once it's all installed
  18. #598 Re: selliott turbo gp
    Kansas City
    Do you think that's a better option than using the new style plug, obviously it's less parts to fail. Just curious, we are going to address this issue on Monday and I don't want to worry about it constantly.
  19. #599 Re: selliott turbo gp
    Aug 2017
    Raytown, MO
    Quote Originally Posted by selliott View Post
    I'm not a fan of running it straight without a connector 1. for convenience, and 2, if that rtv or whatever you use doesn't seal correctly then you're going to have an evap leak, and I don't trust rtv bonding to everything and lasting 10+ years with the heat and vibration. Maybe I'm paranoid, but I don't like the combo of a car with possible fuel vapor leaks. Seeing as 1200HP LS cars have run this style connector and are fine, I'm more prone to trust it. Though if that connector comes off, if the fuel level sensor fails, it's easy to replace with all the spares you have!
  20. #600 Re: selliott turbo gp
    Antioch, IL
    He said evap LOL who the fck runs that ****
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. This build
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2011, 09:19 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
