Thread: selliott turbo gp
Page 29 of 40 FirstFirst ... 19272829303139 ... LastLast
Results 561 to 580 of 785
  1. #561 Re: selliott turbo gp
    I break stuff selliott's Avatar
    Kansas City
    Quote Originally Posted by SgtMarshal View Post
    is that why you had a jacket on above it?
    Yes, the jacket wasn't mine either it was the producers. Hell the jeans weren't mine either
    Sent from my Pixel XL using Tapatalk
  2. #562 Re: selliott turbo gp
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Pretty cool. What was the episode about? How did you get yourself on there?
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  3. #563 Re: selliott turbo gp
    Kansas City
    Quote Originally Posted by CHI2000GTP View Post
    It's the Jeep honcho hemi swap episode. It's filmed where I live and I know the guys at kultured customs.
  4. #564 Re: selliott turbo gp
    Kansas City
    Gear Dogs Jeep honcho
  5. #565 Re: selliott turbo gp
    May 2017
    Dirtyzville, Mizzery
    They're a pretty cool bunch of guys.
    They did the frame off restoration on my old man's 1931 Chevy AE Independence stove pot 6
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  6. #566 Re: selliott turbo gp
    Kansas City
    Quote Originally Posted by blueguy91 View Post
    You should post a couple of pics, that thing is sweet
  7. #567 Re: selliott turbo gp
    did you actually buy that? or was this your acting debut?
    https://youtu.be/BN2wuVsWDQo?t=1739
  8. #568 Re: selliott turbo gp
    Kansas City
    What the hell is wrong with their voices lol sounds like they are sucking helium. I guess it's my acting debut if that's what you wanna call it.
  9. #569 Re: selliott turbo gp
    Damn, I know a celebrity now.
    Can't wait to tell my friends.
  10. #570 Re: selliott turbo gp
    Kansas City
    To late, my 3 seconds is over lol
  11. #571 Re: selliott turbo gp
    Antioch, IL
    Iv heard of 15min of fame but 3 seconds? You must have mentioned your GP LOL
    2009 Challenger SRT8
    Expert at being gay.
  12. #572 Re: selliott turbo gp
    Kansas City
    3 seconds was being generous lol
  13. #573 Re: selliott turbo gp
    Kansas City
    Well finally found the fuel pump problem. Just lucky it didn't burn to the ground.
  14. #574 Re: selliott turbo gp
    hangover park IL
    There's a reason that I drill a hole and rtv seal 2 12gauge wires....metripack 150 (1.5mm) terminals aren't good at higher current
    ~James~ Psychotic Gearhead
  15. #575 Re: selliott turbo gp
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by Turbocharged400sbc View Post
    Those terminals are rated for 20 Amps. No way a properly working system, even a high performance one draws that much. There was some catastrophic failure or physical damage. I would check that the rating on the fuse isn't over 15A then throw some dielectric grease on a new connector. Less chance of corrosion and easier to deal with.
  16. #576 Re: selliott turbo gp
    Mar 2014
    Tucson
    As I understand it, this is the reason GM went to the 4-flat connector.
  17. #577 Re: selliott turbo gp
    Aug 2017
    Raytown, MO
    Quote Originally Posted by BrandonHall10 View Post
    I thought it was more to do with space saving. I've run industrial heating at 15Amps 120V thorough the same terminals with no issues. It could have been a massive power surge or a defect in that particular connector but I highly doubt the connector is to blame. Could be wrong, I'm not an expert or anything, just throwing out thoughts
  18. #578 Re: selliott turbo gp
    hangover park IL
    14 amps...... but it's also sort of telling that all of the updates and all of the newer Vehicles use the flat 4 wire Metra pack 280 connectors for all fuel system units..... this kind of sort of tells you that even GM noticed that the 150 suck
  19. #579 Re: selliott turbo gp
    hangover park IL
  20. #580 Re: selliott turbo gp
    Aug 2017
    Raytown, MO
    Interesting! I wonder how you would change the connector on the fuel pump size wether you'd have to buy a different in-tank module or not. That being said, quote: "any residual damage to the connector mayresult in a voltage drop across the module and can lead to repeat failures." which in means that the connector would have to be damaged in some way to fail that way. However the other connector does look to be a better design. You should be safe with either as long as you inspect the connector to make sure nothing is broken off.
  1. ZZP XPZ Build
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2017, 09:40 PM
  2. This build
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2011, 09:19 PM
  3. $400 gtp build
    By heavyRfoot in forum General Tech Discussion
    Last Post: 03-13-2010, 01:29 AM
  4. New Build
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 08:50 AM
  5. The Build...?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 11-04-2009, 07:35 PM
