Thread: MAP Sensor
Results 1 to 1 of 1
  1. #1 MAP Sensor
    SE Level Member swat0712's Avatar
    Feb 2009
    Pittsburgh, PA
    Ok guys,
    Still haven't fixed my problem, I haven't a chance to work on it much, but I took the TB off today to make sure it was 'clean,' and it looked ok. I put it back on but did not tighten it down all the way and when I started the car it ran like it did previously, but when I gave it some gas it would keep from completely stalling. When I tightened it back down it ran rough still when given gas. When the MAP sensor is plugged in the car will not really even start, when it is unplugged it goes back to running real rough and stalling when not given gas. When the MAF sensor was plugged in it ran the same, when unplugged it would not stall on it's own, I shut it off, but it was surging hard. If you guys have any more ideas they would be greatly appreciated. I'm really trying to avoid taking it to the dealer, especially considering they say they probably won't be able to come up with anything on the computer.
    Original Post:
    Ok everybody,
    One more problem with my wonderful gtp.....I was driving home today, going up a hill the battery light came on, the rpms dropped, and it just died...It will start run badly for a few seconds, making a weird noise, then die. It doesn't move. Luckily I was able to get it the the crest of the hill and coast to the bottom where my house is. I checked my vacuum lines, they all seem to be right, ran the engine with the belt off and it still does the same thing, checked my air filter/ran it with the filter off, same thing...The air filter does look a bit dirtier than when I had it off 2 weeks ago, possibly an oil spot on it? Also, the engine light has not come on, the only lights that come on are the battery light and the low coolant light, and that is a bad sensor. I have a video of the car "running," I'm not sure how much it will help but.....Any suggestions would be helpful, this is my DD so. Thanks in advance!
    YouTube - Car2011.MOV
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Coolant
    By kaiser0427 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2009, 08:03 AM
  3. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
