Stock L67 3800 Series II V6 block
ARP Head Studs
ARP Main Studs
Clevite77 Main/Cam/Rod Bearings
Balance Shaft Delete
GM '04+ L32 Powdered Connecting Rods
GM '04+ L32 TTY Rod Bolts
Stock L67 Pistons
INTENSEā„¢ Stage 3 Blower Cam
Double valve springs, titanium retainers, etc (unsure of which, will get some good ones)
Intense-Racing O/R Stock Length Pushrods
Stock L67 Heads ported, 3-angled, cleaned up by local shop
Manley Stainless Steel valves
Ported Lower Intake Manifold Inlet/Runners
Ported Factory M90 Supercharger:
Ported and polished L67 Throttle body
LQ4 MAF Sensor w/ Open Cone Intake Setup
Modular Pulley System: 3.3 right now
180* Thermostat
Speed Daddy headers
Magnaflow cat-back
Stock coil packs (might upgrade later as money allows)
Some form of good CAI intake setup
Thoughts? Suggestions?
We're going to be swapping this into a 98 GT 2-door. Picking up the engine this week sometime so we can start the build on it.
