Thread: How are you keeping underhood temps down?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #1 Re: How are you keeping underhood temps down?
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    I think I'll just go w/ weather stripping. I like a couple of the aftermarket hoods but I already have enough money wrapped up in this $3000 car.
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: How are you keeping underhood temps down?
    that would be so much work watching your temp gauge and switching it on and off...
  3. #3 Re: How are you keeping underhood temps down?
    Houston
    Yeah I agree, Itd be like removing your thermostat in your house and replacing it with a thermometer and a switch.
  4. #4 Re: How are you keeping underhood temps down?
    you want your coolant moving all the time...
    else you'll get hot spots....
    then worse things happen...
    You want to COOL the coolant once the temp reaches a certain temp.
    Hence the thermostat.
    The electric waterpump allows you to have higher coolant flow rates.
    Gotta have the system capacity for it though.
  1. Did some underhood painting.
    By DCVING in forum Visual/Body Modifications
    Last Post: 09-06-2012, 05:49 PM
  2. When keeping it real, just isn't enough...
    Last Post: 03-21-2011, 11:10 AM
  3. keeping the monsoon, but adding 12 and amp?
    By f3racer in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2011, 11:07 AM
  4. CLeaning up underhood wiring?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 10-17-2009, 10:39 PM
  5. Underhood fuse box
    By Sabrewings in forum General Tech Discussion
    Last Post: 09-21-2008, 06:46 PM
