Thread: How are you keeping underhood temps down?
Results 1 to 20 of 24
  1. #1 How are you keeping underhood temps down?
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    I wrapped my headers and have a fwi, but I still feel like I'm going to be pulling hot air into my engine. Like my air intake tube will get hot. I made it out of 3 1/2" aluminum tubing. Should I wrap that w/ header wrap or will that not do anything? I'm thinking about making a heat extractor in my hood. Any ideas or input?
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  2. #2 Re: How are you keeping underhood temps down?
    why do you care? jw cuz it doesn really matter that much
  3. #3 Re: How are you keeping underhood temps down?
    Donating Users
    South Deerfield, MA
    I did some measuring of underhood temps before I put my headers on. Stainless steel does not conduct heat as well as mild steel. I had a drop in underhood temps after my header install compared to the stock manifolds and they were not coated.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: How are you keeping underhood temps down?
    Charles City, IA
    I use midgets with a fire hose.
    All I have done is pull the weather strip at the top of the fire wall.
    SMGPFC Two Nipple General
  5. #5 Re: How are you keeping underhood temps down?
    Quote Originally Posted by TheOtherNick View Post
    win lol
  6. #6 Re: How are you keeping underhood temps down?
    Dec 2008
    PA
    The weatherstrip is a good idea. But the midgets could be good too. What kind of salary do they require?
  7. #7 Re: How are you keeping underhood temps down?
    just borrow a few of Angalina Jolies kids... ^^^^
  8. #8 Re: How are you keeping underhood temps down?
    Charles City, IA
    I stole umpa lumpas from willy down the road, they agreed to work for free if I dont butt sechs them. Like he did.
  9. #9 Re: How are you keeping underhood temps down?
    Jan 2009
    Tallahassee, FL
    I've taken the drip tray (Daytona) off the hood and taken the weatherstripping out.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: How are you keeping underhood temps down?
    no hood, duh.
  11. #11 Re: How are you keeping underhood temps down?
    Ohio
    no hood, duh.
    right, right...theres a tricked out looking civic with highlighter green engine parts that cruises these parts with no hood. massive power gains or he just wants everyone to see his vtec
  12. #12 Re: How are you keeping underhood temps down?
    it doesnt matter. when youre moving its ambient +10* or so under the hood.
  13. #13 Re: How are you keeping underhood temps down?
    And when you are sitting still...it's for the loss no matter.
  14. #14 Re: How are you keeping underhood temps down?
    Mullet Member Wotgtp's Avatar
    Connecticut
    My weather stripping, engine cover and drip pan on my daytona were already removed when I bought it, lol.
  15. #15 Re: How are you keeping underhood temps down?
  16. #16 Re: How are you keeping underhood temps down?
    Donating Users crock's Avatar
    Traverse City, Michigan
    Just take your hood off.....
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  17. #17 Re: How are you keeping underhood temps down?
    Pennsylvania
    You engine is full of little explosions.
  18. #18 Re: How are you keeping underhood temps down?
    Wichita, KS
    I changed my fan settings.
    I run a 180* t-stat.
    I run an electric water pump.
    I have TOG coated headers (un wrapped)
    Probably the BIGGEST help is the MPD F1 hood.
    ~F~
  19. #19 Re: How are you keeping underhood temps down?
    I still hate aftermarket hoods though.
    I'll just leave my weather stripping off.
  20. #20 Re: How are you keeping underhood temps down?
    Dec 2008
    PA
    I think I'll just go w/ weather stripping. I like a couple of the aftermarket hoods but I already have enough money wrapped up in this $3000 car.
  1. Did some underhood painting.
    By DCVING in forum Visual/Body Modifications
    Last Post: 09-06-2012, 05:49 PM
  2. When keeping it real, just isn't enough...
    Last Post: 03-21-2011, 11:10 AM
  3. keeping the monsoon, but adding 12 and amp?
    By f3racer in forum Audio, Security & Visual Electronics
    Last Post: 01-31-2011, 11:07 AM
  4. CLeaning up underhood wiring?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 10-17-2009, 10:39 PM
  5. Underhood fuse box
    By Sabrewings in forum General Tech Discussion
    Last Post: 09-21-2008, 06:46 PM
