Thread: HUGE bog off the line
Results 1 to 8 of 8
  1. #1 HUGE bog off the line
    Florida
    Hello forum. Just bought a 2000 GTP and when I take off from a dead stop and PUNCH it, the car spins the tires for a second....looses all power and the takes off. The boost comes on, but I dont feel it pulling like it should.
  2. #2 Re: HUGE bog off the line
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Does it die without the traction control on, as well?
  3. #3 Re: HUGE bog off the line
    Florida
    Thats another issue...the TRAC OFF lite stays on all the time. I have an issue with the driver hub I am addressing.
  4. #4 Re: HUGE bog off the line
    Dec 2010
    Canada
    Is all maintenance up to date?
  5. #5 Re: HUGE bog off the line
    Florida
    Here is what was done so far by previous owner.
    New plugs ( Going to pull and check type and gap )
    New wires ( Advanced brand )
    Rebuilt trans ( Local Trans shop )
    New cold air intake ( PST Performance?? )
    New Coils and Module ( Advanced )
    New fuel filter ( Fram )
    MAF - Used
    TPS - Used
  6. #6 Re: HUGE bog off the line
    Florida
    OK, new update. Got the car on a scan tool at my buddy's shop. P0102,P0172 and P1133. Two O2 and one mass air. The mass air code was handled by just cleaning it. The O2 was reading wierd, but not faulty. The car was way rich all through the ranges even at idle causing surging. 2 things were found. The aftermarket air intake from when I bought it had three different sized adapters inside causing a restriction in side before the mass air. The stock boot from a doner car and a straight section on PVC to the cone filter and problem with idle richness corrected and the bog is gone. Secondly found that for some reason there was alot of timing in the car ( 33 deg ). Did a relearn on the crank sensor and car runs, idles and drives great now.
  7. #7 Re: HUGE bog off the line
    London Ont, Canada
    once the hub is fixed the track will work again, i had the same issue on my 99
  8. #8 Re: HUGE bog off the line
    33* of timing??? LOL wut.
    Just make an intake like this...keep it simple.
  1. Huge sticky!!
    By blueguy in forum General Tech Discussion
    Last Post: 07-04-2009, 08:38 AM
  2. wll huge k&n filter fit in wizaired?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 12:09 AM
  3. Huge Problem...Help Needed!!!
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2008, 01:09 AM
  4. I Had A Huge Scare!
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2008, 05:36 PM
