Thread: Car cuts out under boost w/ vids
Results 1 to 19 of 19
Threaded View
  1. #1 Car cuts out under boost w/ vids
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    Ok guys finally got the car finished with all vac leaks fixed everything seems to be sealed. If you must know i verified the vac leaks by lowering my air compression regulator and with my homemade intake designed for this i shot air into the intake to listen for leaks and i finally got it all sealed. All the mods are in the signature below.
    This i have tried.
    -Changed pulleys to see if it was belt slip no change and scan showed that
    -changed plugs and wires and didnt help
    -thought MAYBE MAF tune was off so i changed back to stock and no change
    -When i scan no misfires come up under load.
    -Spark plugs are gapped at .042 and timing is at 24* (car has ran at this before hand with no issues)
    -changed plug gap to .049-.050 nothing changed
    -EGR is blocked off for intercooler
    -Checked voltage to make sure alternator was keeping up and is at a steady 14.3v
    -check vacuum at idle with the 3.0 i see approx -15-16
    -Replaced fuel filter
    -Changed fuel regulator still nothing changed
    -Fuel pressure at idle is 60 and at wot when it starts to cut out is around 62-65
    -Brought the ICM back down and made sure it was ground and still no change
    -Took supercharger belt off and ran it that way and it still dies off at 5k rpm (can not do case relearn)
    -Ran open cone on crank case to make sure i wasnt generating to much pressure
    I dk if that has anything to do with it but could my PCV not be correct and create crank pressure and allow it to do this? Got it going from the TB (between MAF and blades) to the oil neck on the VC. The rear PCV is capped and block on the intercooler and s/c. I routed the rear pcv to the TB and ran open cone and seems to have gained a little more vacuum and idle a littler better.. Could it be possible that i might be loosing ground? My ipw dont get past 15. I does not indicate any misfires under load.
    I cant even do a crank case relearn because it dies out under high rpm.
    Im at a loss. Any ideas would help.
    Video's
    YouTube - Grand Prix GTP mods
    YouTube - Grand Prix fuel pressure at idle
    YouTube - GTP cutting out under boost
    YouTube - Fuel pressure when cutting out under boost
    YouTube - Vacuum when care cuts out under boost
    YouTube - Grand Prix GTP Xp cam idle
    The wideband needs to be fixed so DO NOT look at the gauge.
    Just your normal 730whp 4dr family car.
  1. Installed Locx (rca converter) and now sub cuts out
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 11-05-2010, 11:25 AM
  2. Engine surges and cuts out
    By timmyg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2010, 04:26 PM
  3. Engine cuts out
    By DLAVENGER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2010, 10:07 PM
  4. OPEC Cuts Production, Prices Fall Anyway
    Last Post: 12-18-2008, 10:55 PM
  5. @115 Engine Cuts out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-23-2008, 09:51 AM
