I recently acquired a 1997 GTP with higher mileage, the guy I got it from was frustrated with it so he was passing it on to me. He was having a problem with it overheating also. So I get it home and think it is just air in the system after he replaced lower intake gaskets, so I bleed the system and it took about 1.5 gallons of the green stuff. So I test drive it about 40 miles or so and no problems what so ever, so I am thinking. I drive it to work a couple days later and on the way it is all good. On the way home though different story, leave work 5 minutes into trip it overheats????? I think to myself what was different? I know the first two times I drove it I had the defrost on as it was cold out. I read that with the defrost on or the a/c running the electric cooling fan is running? So I just checked for power at the connector and I am not getting anything, but also when I tried to direct wire the fans, they did not run either or nor did they blow the fuse? I am at a loss I am assuming I can power the fans directly at the fan plug by applying ground and power, that is what I tried to do and they did not kick on. I have a wiring schematic from alldata, but it is a little confusing. Any pointers???? I had also had the dreaded blower motor only working on high, changed control module no change??? Is the cooling fan also powered off the electrical ignition switch in some way, I am thinking that may be the culprit. Just a little foggy on electrical stuff. Thanks in advance.
