Thread: holes in the plenum
Results 1 to 7 of 7
  1. #1 holes in the plenum
    Apr 2011
    Tampa
    I removed the plenum since I'm replacing some gaskets on my 98 GTP. Under the plenum there are 4 water-jet pockets and two are blocked by some kind of material. Its hard to tell if they are supposed to be blocked or not. It looks like some filler material so I poked a hole through it with a screwdriver. I either need to repair those hole seals or open them. It seems kind of weird so what do you think?
  2. #2 Re: holes in the plenum
  3. #3 Re: holes in the plenum
    PCV
    EGR
    Coolant ports
  4. #4 Re: holes in the plenum
    Jan 2009
    Tallahassee, FL
    Is is an orangebronze color? If so could be the all to notorious GM dexcool.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: holes in the plenum
    Donating Users
    South Deerfield, MA
    Look at the bottom of your intake manifold. Only two of the holes actually pass coolant through. Clean all the built up crap out of the two plugged holes to stop it from breaking loose and plugging up your cooling system.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  6. #6 Re: holes in the plenum
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Those are your throttle body coolant passages. A lot of people usually block them off anyways, But to do that you usually use a filed dime. Like stated above clean the stuff out and put it back together. I doubt that the gasket material will plug up the collant system.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  7. #7 Re: holes in the plenum
    Quote Originally Posted by t24moore View Post
    L36/L26 manifold doesn't have the recessed areas for the coolant o-rings like the L67 manifold does. It's best to use 1/4" NPT pipe plugs w/o heads.
  1. Upper Plenum
    By chev1988rolet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2010, 08:16 AM
  2. holes behind skirts?
    By irupp33 in forum General Tech Discussion
    Last Post: 03-29-2010, 04:42 AM
  3. Spoiler holes
    By GOINDEF in forum Visual/Body Modifications
    Last Post: 03-25-2010, 11:44 AM
  4. firewall holes?
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2009, 12:22 AM
  5. i hate pot holes
    By nemesis in forum The Rant Forum
    Last Post: 02-20-2008, 02:02 AM
