Thread: removing emissions
Results 1 to 8 of 8
  1. #1 removing emissions
    Bunnell, FL
    i found out my car has cal emissions, i live in fl where there's nothing. is there a write up on how to remove everything? i did search and found a reference to a post in 08 but no dice
    I'm a Sex Offender
  2. #2 Re: removing emissions
    St. Louis
    Ok, so you know it has cal. emissions equip. Now we need to know the year and model of your car as it may vary. Is it a SE, GT, or GTP?
  3. #3 Re: removing emissions
    Bunnell, FL
    97 gtp
    I'm a Sex Offender
  4. #4 Re: removing emissions
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Just remove the evap canister and egr. You need to block off the rear manifold egr hole with something and the EGR hole on the LIM.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  5. #5 Re: removing emissions
    Then get the codes tuned out, so the SES light wont be on all the time.
  6. #6 Re: removing emissions
    Bunnell, FL
    any pics?
    I'm a Sex Offender
  7. #7 Re: removing emissions
    Pennsylvania
    What are you doing to the car that you need to remove emissions equipment?
    The EGR is a good thing for a daily driver. Not sure about how the AIR system, helps or hurts performance, though.
  8. #8 Re: removing emissions
    Florida
    I am in daytona send me a PM and we can set it all up. i have a tuner and i can turn off the codes for you. and give you some tuning while at it!
  1. Oh, Emissions...
    By smcglaug18 in forum The Rant Forum
    Last Post: 08-17-2010, 08:51 AM
  2. Help - Can't Pass Emissions
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2010, 03:42 PM
  3. Overkill Pcm, emissions
    By Perry125 in forum PCM Tuning
    Last Post: 02-25-2010, 09:42 PM
  4. Evap Emissions Code
    By Rebuilder in forum 04+ Specifics
    Last Post: 12-10-2009, 05:08 PM
  5. emissions
    Last Post: 02-22-2009, 11:56 PM
