Thread: number 3 mifire help
Results 1 to 12 of 12
  1. #1 Re: number 3 mifire help
    Try to get a new wire that is the correct length...I used to have issues on that on my old buick.
  2. #2 Re: number 3 mifire help
    Mercer, Pa
    Sounds like you eliminated fuel and spark. How about vacuum leaks? They don't have to be big to effect idle.
    What kind of car?
    How many Miles?
    What year?
    supercharged or NA?
    Has the lower intake gasket been changed?
    if NA, has the upper composite intake been changed yet?
  3. #3 Re: number 3 mifire help
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    Ok, sorry about not giving all the details. Car is a 1998 pontiac grand prix GTP with the L67 we have checked all the vaccume lines and there are no leaks found one a while back but fixed it for sure. The car has just under 147k miles on it. From what it looks like the previous owner put no LIM gaskets on so those should be ok. I may try and get a set of wires soon to see if it helps just trying to get a general view on what could be causing the misfire only at idle...
  4. #4 Re: number 3 mifire help
    Mercer, Pa
    Quote Originally Posted by Spartanzz View Post
    From what it looks like the previous owner put no LIM gaskets on so those should be ok..
    Stock LIM gaskets are a none failure point with that many miles. As I understand it is normally a coolant leak but still something to check
  5. #5 Re: number 3 mifire help
    Dec 2010
    Lawrenceville, GA
    yeah ill give it a look over looking at starting to mod so may get my hands on a ported SC and LIM just gatta find a good deal on um.
  6. #6 Re: number 3 mifire help
    If you try everything and that doesn't solve it.. swap the ICM. I know..it fires both towers etc etc. I've seen two cases where the icm didn't fire on one of the two cylinders. Odd eh?
  7. #7 Re: number 3 mifire help
    Dec 2010
    Lawrenceville, GA
    Well not too long ago my icm stopped firing on 3 and 6 so replaced that and before that happened o still had the idle misfire then got a brand new icm and idle misfire still there...I still drive the car every day so its not bad enough to destroy disability at this point its just getting annoying lol
  1. number 4 misfire
    By kawasakidrivinghick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2011, 03:13 PM
  2. whats the part number for this?
    By jayetune08 in forum General Tech Discussion
    Last Post: 08-21-2010, 10:43 AM
  3. Next user is number 10,000
    By Rocket468 in forum Off Topic Discussion
    Last Post: 11-18-2009, 07:58 PM
  4. car number?
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-31-2009, 11:36 AM
  5. Need a Part Number....
    By webracin in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2008, 01:54 PM
