Thread: fuel pump issues
Results 1 to 5 of 5
  1. #1 fuel pump issues
    pennsylvania
    Well my car will crank but wont rund it will start up for a second with starting fluid. Took off fuel line in engine no fuel coming out. Took off fuel line before fuel filter nothing no fuel. The pump is not clicking. But the fuel pump is brand new only 3 weeks old. WHat fuses should i check i did check most of them anything that said injection or anything to do with fuel, Where is the fuel pump relay at could that be it?
  2. #2 Re: fuel pump issues
    pennsylvania
    Any ideas
  3. #3 Re: fuel pump issues
    i believe the relay is under the hood in the fuse box, or if you got a tester (multimeter) you could test the wires that plug into the fuel pump for power.
  4. #4 Re: fuel pump issues
    Three weeks old means recent work. Pull the pump cover in the trunk and check all the connectors. It's too random that you would have just blown a fuse or all of a sudden had a relay issue. Always aim to the most currently touched stuff if it seems related.
    Likely one of the connectors wasn't seated fully and it backed off enough to cause a power issue.
  5. #5 Re: fuel pump issues
    pennsylvania
    well the wire harnass hooked up to fuel pump must of been of a hair cause i barley touched it and it started right up
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. 97 GTP Idleing issues or fuel pump? Help if you can.
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 01:14 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
