Thread: Coolant in TB
Results 1 to 13 of 13
  1. #1 Re: No Idea - Please Help!!!
    I live here. TLSheff's Avatar
    Basic principle is the engine runs the Alternator, which recharged the battery, which is constantly being drained by the engine. If the Alt isnt working, the battery will get low enough, the light will come on at the cluster, car will gradually lose power and eventually won't even try to turn over after it dies.
    If you can get it to run for any amount of time with it being jump started (ie, running off another cars alternator, thusly charging your dead battery) then it is either the battery has a bad cell and won't hold a charge *replace it*, or the Alternator is toast *replace it*
    If you have alt means of transportation, pull the alt and the battery both, truck them downtown to a local parts store, 90% of them have machines to test both. Its usually free and worth the time to do this
  2. #2 Re: No Idea - Please Help!!!
    SE Level Member swat0712's Avatar
    Feb 2009
    Pittsburgh, PA
    Ok,
    So the alternator was bad, I got it rebuilt, but it seems like it's still not getting the power. Guy at autozone said something about the lead where it goes into the starter has some type of "fuse" that might be shot? I'm looking online now to try and find out how to fix, but anymore suggestions would be helpful! Thanks again!
  3. #3 Re: No Idea - Please Help!!!
    Banned Trolling GPF
    Quote Originally Posted by swat0712 View Post
    Ok,
    when whoever refurbished your alternator refurbished it...wouldnt they fix this issue? just sayin
  4. #4 Re: No Idea - Please Help!!!
    Feb 2009
    Pittsburgh, PA
    Fusible link was the term I was looking for back in the last post. No, he just rebuilt the alternator, this is supposedly somewhere between the alt and the starter, a safety feature so that if the alt shorts it stops the short before it fries the rest of the car.
  5. #5 Re: No Idea - Please Help!!!
    Banned Trolling GPF
    ic...sorry for my incompetence lol
  6. #6 Re: No Idea - Please Help!!!
    Feb 2009
    Pittsburgh, PA
    well I guess that makes us both incompetent, because I didn't know anything about a "fusible link" either until about 20 minutes ago lol...anyway, I think I have the the basic info, but if anyone knows whereabouts the links would be that would be helpful. I'm thinking about going with an alt rewire, any suggestions?
  7. #7 Re: No Idea - Please Help!!!
    Feb 2009
    Pittsburgh, PA
    Ok guys,
    The Alernator's been replaced and the car still dies. When the main belt is off the car runs on the battery. When you put the belt on it runs for about 2 seconds then dies. No fusible links are bad, I've had everything checked out alternator wise. I'm assuming it must be a vac line or sensor of some sort. Any thoughts on that? I'd appreciate any help I can get, I really don't want to have it towed to a dealer to find out it's something simple. Thanks again
  1. Good Idea or Bad Idea?
    By Robby Avery in forum Turbo
    Last Post: 01-25-2011, 04:55 PM
  2. Idea - put a 5.3V8 in my 00 GT
    By bankai in forum General Tech Discussion
    Last Post: 10-01-2010, 04:13 PM
  3. idea....
    Last Post: 04-19-2010, 05:41 PM
  4. Good idea - Bad idea?
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 04:51 PM
  5. Need idea's for my car!
    By Justin33 in forum Visual/Body Modifications
    Last Post: 08-03-2009, 11:38 AM
