Thread: Bryant changes his mind faster than any woman...and some Cam Help...
Page 8 of 9 FirstFirst ... 6789 LastLast
Results 141 to 160 of 178
  1. #141 Re: help after cam install :(
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    it was not meeeeeeeeeee.
    and it just kinda sucks bcuz u put all this time and money into a car than sdtuff liek this happens lol
  2. #142 Re: help after cam install :(
    Bryant.. my first cam install on my own I had other people working on stuff in the garage and I was seriously overmultitasking.
    I put air to the cylinders with the entire bottom end unbolted. Wasn't thinking at all. Blew a piston out the bottom of the motor. Basically killed the motor out of the car, on an engine stand. Put it together in hopes it was ok. Started it found the flex holes were egged, it was installed 180 off. Pulled and fixed that. Then drove 200 miles before the bearings let go. Got another motor, put everything into it and it was knocking in under 5 miles. Just a bad motor. Swapped it again and that motor was amazing.
    Hang in there.. yours is an easy fix hopefully. You'll get it.
  3. #143 Re: help after cam install :(
    Quote Originally Posted by BoostnBlackGTP View Post
    dude i said with no dampner lol the pic is just without it on lol
    BoostnBlackGTP> it had play with the tensioner on
    ... and we also found that on the crank gear the teeth on the outer edges are rough like they were being ground up..
    And what i was saying is the teeth on the cam gear are rough and seem liket hey have slightly been grinding thats why they r rough to the touch not smooth
    I'm gonna limp... from breakin my foot off in your azz. Can we change the name of this thread to "Bryant changes his mind faster than any woman"
  4. #144 Re: help after cam install :(
    Waterloo, Iowa
    i neevr said anything about it with the tensioner off bill.
    Just the pic is with it off. The fvcking chain had play in it with the god dam tensioner on. jesus fvcking christ
  5. #145 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Bryant, please back up and read what your screen name typed. You said exactly what I quoted. Nick said with the tensioner off it had play, you reiterated what he said.
    Slow down your typing when you have a problem. It'll make the diagnosis much easier. Because so far this entire thread has been 3-4 of us making suggestions based on your typing contradictions.
    See why everyone is typing in caps to you?
  6. #146 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Caps mean were yelling...because were mad.
    Duh.
    You got the wrong cam gear. Fix it.
  7. #147 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Waterloo, Iowa
    its jsut a aftermarket cam gear.
  8. #148 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Title change FTMFW
  9. #149 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Waterloo, Iowa
    k well besides u guys being fvcking stupid. i want to figure this out. R the timign chain and gears for a s/c and non s/c car diff?
  10. #150 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Doesn't mean its working right.
    Should have just used your stock one.
  11. #151 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Gears and chain are the same NA to SC.
    I cam swap motors all the time, there's no grinding. Who's being stupid? Who is quoted above as being contradictory to the guys trying to help him? Who is the one swaering up a storm?
    Be careful..you might find that guy if you look in a mirror.
  12. #152 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    THIS.
    fashobrah
  13. #153 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Jan 1970
    Maquoketa, Iowa
    X2 **** happens, but most people just buy a new stock timing chain and dampener and that's it, not from an auto parts store but from the dealer itself, one of the vendors so it is OEM.
    Just take your time and don't rush anything when you put it back together, it's your car so triple check things, ask questions and get it right this time and be happy when it's over. People are giving you so much **** because they've been there before or done worse at one point.
  14. #154 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    GT Level Member RegalGS98s's Avatar
    NJ
    Put your stock gears back on, get a new chain and call it a day.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  15. #155 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Nooo we are giving him **** because he keeps contradicting himself. I've known women that made more sense.
  16. #156 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    NJ
    Quote Originally Posted by billboost37 View Post
    nooo we are giving him **** because he keeps contradicting himself. I've known women that made more sense.
    lol x2
  17. #157 Re: Bryant changes his mind faster than any woman...and some Cam Help...
  18. #158 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Portland Oregon
    Please do yourself a favor as well and get a new cam bol as it is also torque to yield
  19. #159 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Waterloo, Iowa
    for bill :
    here is my new crank/cam gears and timing chain
  20. #160 Re: Bryant changes his mind faster than any woman...and some Cam Help...
    Odd...
    And, how'd it work?
  1. My Woman Ditched Her Cavalier...
    By blueguy in forum Off Topic Discussion
    Last Post: 09-11-2014, 11:28 PM
  2. Have to watch this, Woman wakes up to find intruder in her bed.
    By Lsick7 in forum Off Topic Discussion
    Last Post: 08-05-2010, 04:27 AM
  3. What should I get the woman for christmas?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 12-16-2009, 06:41 PM
