Quote Originally Posted by miker56 View Post
Make sure u get the metal LIM gaskets! And switch the Green coolant, i run that in my 07, make sure u flush ur heater core (two hoses that come out of the fire wall) and the radiator, as the green and dex will gel when mixed. Good luck!
Not to take it off topic, but if you use Prestone Any Color, you can relax a little bit with having to get every last spec of dex out of your system. Some of that stuff can continue coming out for days worth of fill up > run > drain.
Just makes things a little easier.
I flushed and flushed until the water was coming out absolutely clear, but then I filled it up with any color, drove it for a week and peeked inside the filler neck, was a green and red mess.
Drained it all out till it came out clear again, refilled it, looked inside just a few days ago and it was all green and red mixed again. Gunk just keeps dissolving out into it I guess.
