Thread: IC hose fittings?
Results 1 to 5 of 5
  1. #1 IC hose fittings?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Since I'm going to do some custom work on my IC install, WHERE do you find those barbed hose fittings? 90* 3/4 to 3/4 elbows, 1" to 3/4" reducer...etc. I couldn't find any at Lowes.
    Also, those using clear hose, are you using that reinforced stuff from Home Depot that is rated at 150 psi @ 72*F? What is the real temp rating for that stuff?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: IC hose fittings?
    chicago
    i think zzp sells the barb fitting kits. if you have grainger in your area they prob have all the stuff you need.
  3. #3 Re: IC hose fittings?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    I got some copper ones at Lowes.
  4. #4 Re: IC hose fittings?
    St Louis MO
    I looked at copper elbows, but the 1/2 was too small and the 3/4 too large. They didn't have and of the brass barbed 3/4.
    I went to Ace (my ace in the hole when it comes to fasteners) and found the 90* PVC fittings. What I didn't realize was the 3/4 fittings are only 1/2 ID. a copper fitting would be much less restrictive. Although the ends on the IC core is only about 1/2.
    Thanks for the ZZP and Grainger tips as well.
    2010 Camaro SS LS3
  5. #5 Re: IC hose fittings?
    Las Cruces, NM
  1. GM parts listing worthless, need help finding hose
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 11:07 PM
  2. Radiator Hose Diameter
    By 03GPScottyd in forum General Tech Discussion
    Last Post: 05-20-2008, 03:01 PM
  3. Corrugated Fuel Hose
    By japslpr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2008, 10:10 PM
  4. Who's Done Homemade Fuel Rails (With an fittings)
    By RNUOVR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 04:13 PM
