Thread: number 4 misfire
Results 1 to 10 of 10
  1. #1 number 4 misfire
    new york
    OK i just started having a problem with my 01 grand prix GTP it started misfireing and i went to the dealer got the code ran it said number 4 misfire i changed plugs and wires in the summer, so i just changed number four plug and wire, still nothen im gonna take fuel injector off and blow it out and then switch it see if it changes anyone else have this problem??
  2. #2 Re: number 4 misfire
    Most likley it's the wire or plug. Which brands did you use? Is the plug wire hitting the exhaust or the O2 wiring? Is the coil post firing for that cylinder?
  3. #3 Re: number 4 misfire
    Check the coils as well...if you swapped plugs and wires and it still acts up...even crappy plugs work ok for awhile...but I recommend Autolite 606's and some Duralast lifetime warranty wires if you don't ever plan on modding it.
  4. #4 Re: number 4 misfire
    new york
    thanks guys got it all figured out it was the coil. Now the only problem i have now is when on the gas and i go over a bump the car will vibrate even when i do a sweeping turn to the right but if i let off the gas it will go away.
  5. #5 Re: number 4 misfire
    St. Louis
    So you make a right turn on the gas and it growls/vibrates? If so it sounds like the hub assembly on the left (drivers) side is going bad. Either that or a CV joint.
  6. #6 Re: number 4 misfire
    new york
    vibrates
  7. #7 Re: number 4 misfire
    I doubt the vibrating has anything to do with misfiring.
  8. #8 Re: number 4 misfire
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    wow, im having the same issue with my car, its a 97 and same cylinder. i started it this morning for the first time in 4 days and fired right up without rpms jumping around, let idle for a few minutes, pulled the plug on that cylinder and it soaked with fuel. sound familiar, cuz im leaning towards an injector too, never thought of the coil.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  9. #9 Re: number 4 misfire
    new york
    mine was the coil
  10. #10 Re: number 4 misfire
    Nov 2010
    south east AZ
    hey dont know how yours acted to determine the coil was bad, but i pulled the wires and plugs from number 4 and 2 cylinders and plug them into the wires and had my gf turn the car over. number 4 fired weak, prolly cuz thats the one that keeps fouling out, but put the number 2 plug in the number 4 wire and it fired strong. did yours not fire at all?
    01 T/A WS6-SOLD
  1. Next user is number 10,000
    By Rocket468 in forum Off Topic Discussion
    Last Post: 11-18-2009, 07:58 PM
  2. scangauge II number crunching
    By BoostedComp in forum General Tech Discussion
    Last Post: 08-19-2009, 11:12 PM
  3. car number?
    By UR LOSN in forum Off Topic Discussion
    Last Post: 07-31-2009, 11:36 AM
  4. ECM service number for re-order
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-06-2008, 01:35 PM
  5. Need a Part Number....
    By webracin in forum Audio, Security & Visual Electronics
    Last Post: 03-28-2008, 01:54 PM
