Thread: P0332 popped up on the way home
Results 1 to 11 of 11
  1. #1 P0332 popped up on the way home
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Looks like its knock sensor related. Which one? Should i just replace it? Knew it had something to do with my 1.9 knock retard whenever i accelerated.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: P0332 popped up on the way home
    Dunno...what's the name on the code? If you can post it..you can certainly tell us the name of the code at the same time.
  3. #3 Re: P0332 popped up on the way home
    Bowie, MD
    P0332 Knock Sensor 1 Circuit Low Input (Bank 2). Which one is bank 2?
  4. #4 Re: P0332 popped up on the way home
    Ohio
    rear of the car..the only one you read from....get under there, blindly take the old one out, get drenched in coolant, finger tight the new one in, torque it to the proper specs....put some more coolant in done
  5. #5 Re: P0332 popped up on the way home
    Bank 2 should be the rear sensor. Sorry to say.
    Torque is 14 ft lbs
  6. #6 Re: P0332 popped up on the way home
    Bowie, MD
    All man just put all that coolant in from the cam install lol. Thanks guys for the info. Gonna go get a new one now.
  7. #7 Re: P0332 popped up on the way home
    Soooo pull the sensor and let it drain into a bucket. Put it back in.
  8. #8 Re: P0332 popped up on the way home
    Bowie, MD
    Yea that does makes more sense lol. Will i hurt the engine if i take too long to replace the sensor and keep driving?
  9. #9 Re: P0332 popped up on the way home
    Oh rear knock sensor.
    Almost damn near impossible.
    Enjoy the cursing that's bound to happen.
    Ohio
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    Yes, the engine will think there is knock all the time and it could start scaling higher. My friends sensor went bad and he would hit 14° just accelerating slowly.
    Get it done ASAP
  11. #11 Re: P0332 popped up on the way home
    Bowie, MD
    Got under the car and turned out to be a cut knock sensor wire. So glad.
  1. Stainless steel line popped loose
    By Trevjar in forum Engine
    Last Post: 09-19-2012, 07:09 AM
  2. Home audio/ home theatre system
    By blakgtp in forum Off Topic Discussion
    Last Post: 03-28-2012, 02:07 PM
  3. Ignition issues, maybe popped a piston?
    By Summer Time Anytime in forum General Tech Discussion
    Last Post: 08-31-2011, 11:16 PM
  4. 99 GTP Popped Codes, and questions for a newbie.
    By Fricker in forum General Tech Discussion
    Last Post: 09-23-2010, 05:17 PM
  5. P0332 code
    By IllegalIntentions in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 01:45 AM
