Thread: Help.. Strange Idle (video) after 1.9's/LIM gasket -
Results 1 to 13 of 13
  1. #1 Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Donating Users Brooks's Avatar
    Nov 2009
    baltimore, md
    Attempted cam install, failed to get the crank pulley off. While I was down there I replaced the LIM gasket and put the 1.9's from my shelf back into the genV. I have plog/pem 3'' down pipe, ngk55's gapped .045.
    SES came on, powrtunr scan said lean fuel trim and misfire. Cleared it and it hasnt been back since.- As far as driving acceleration, WOT , cruise, MPG is good it just seems to be idle. It would be nice if all I had to do was raise the idle RPM, but instincts say its something more then that.
    I have checked/switched plugs
    checked/switched wires
    removed and inspected injectors
    changed fuel filter
    changed vac tubing
    checked s/c gasket
    I have included a video of idle to help troubleshoot. One is just the exhaust because you cant hear it well in the garage.
    Your help is always appreciated.
    Off Idle
    Scan
    Gen V 98 Regal GS
    Baltimore, MD
  2. #2 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    lean fuel trim= Vac leak. Pegged LTFT's=vac leak. Id say you have a vac leak lol
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Donating Users
    South Deerfield, MA
    Did you try using some brake clean to search for a vacuum leak? That's what it looks like to me too.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Jersey
    vacuum leak
    16' wrx sti- stock
  5. #5 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    GT Level Member fri3dchick3n's Avatar
    Alaska
    Quote Originally Posted by Silver GTP View Post
    There is a way to find where the leak is coming from? How?
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180º Thermostat, Flipped Dog Bones
  6. #6 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Central Florida
    by using brake cleaner or carb cleaner and spray around all the areas of vacuum(LIM, TB, vac lines, booster, ect.) and whenever you hear or see it idle up/rev up you have found your vac leak.
    done it a few times on a contour i had and my 6
    1998 Pontiac GTP - rebuilding
    1991 Mazda MX6 GT - DD
  7. #7 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Nov 2009
    baltimore, md
    Excellent, much gratitude to both of you for the help. I can't imagine what inflated number a shop would have charged to do that 30minutes worth of work.
    Spraying brake cleaner showed a sneaky leak under the blower snout due to that rediculous metal s/c gasket. Put the old zzp gasket back on with some gasket maker and its working great now.(I've ordered a new replacement)
    Friedchicken - Its really easy, check youtube for videos of people spraying their engine, either carb cleaner or brake cleaner will work and listen for a change in the engines idle. I sprayed around all the vac lines first then worked my way down.
    Gen V 98 Regal GS
    Baltimore, MD
  8. #8 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Buy a GM gasket...what are you using...that Garleak junk?
  9. #9 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    utah
    ^this
  10. #10 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    garlock suck balls man use a oem gasket i had a garlock with my ssm90 kit and it leaked then bought oem and it was fine
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  11. #11 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Hagerstown,Md
    Ill play devils Advocate. Ive been running on a Garlock for 2 years on the IC and a Garlock for 6 years on the TB
  12. #12 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Quincy, Mass
    make you own gaskets, the material is like $10 a role or something at advance or napa and use some gasket maker goop around the hole thing too. and the gaskets arent the problem its how evenly you torque it down.
    No more GP 04 Impala SS Indy:
  13. #13 Re: Help.. Strange Idle (video) after 1.9's/LIM gasket -
    Houston
    Def a vac leak...your vac is only seeing -10 at idle. Mine reads about -16
    *Edit: Nevermind, I see it's been resolved. Thats why you read everything before posting..lol
  1. Replies: 84
    Last Post: 09-09-2015, 08:10 PM
  2. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  3. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  4. and...the build begins *UPDATE*IDLE VIDEO!!!
    By glanzergtx in forum General Tech Discussion
    Last Post: 06-07-2010, 03:19 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
