Thread: Few new questions.
Results 1 to 4 of 4
  1. #1 Few new questions.
    SE Level Member chrisgsx's Avatar
    Nov 2010
    Michigan
    Ok so i just did a motor swap on my 97 gtp, with a motor from a 98..i got all the wiring hooked up, and all the vacuum lines hooked up, and now i start the car and it runs terrible and smokes out my garage. It threw a p1626 code, but that does not seem to be the issue..it runs like it has a huge cam in it, and the headers get suuuper hot even after running for like 30 secs. any help would be appriciated thanks guys
    97 gtp in peices...
    01 Regal gsx 3.4mps SD headers, 1.9 mod rockers etc etc
  2. #2 Re: Few new questions.
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    well p1626 is Theft Deterrent Fuel Enable Signal Lost so u could be running lean check all your connections make sure there are no broken wires also wich pcm are you running the 98 or 97 pcm cause if u have a 97 gp u need a 97 pcm 98+ wont work
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  3. #3 Re: Few new questions.
    Nov 2010
    Michigan
    all connections are good and im running the 97 pcm, im not sure why its bringing up that code..
    97 gtp in peices...
  4. #4 Re: Few new questions.
    ya thats weird but isnt that code somthing to do with the bcm
    sold 97 GTP stock
  1. Few Questions :)
    By GrandPrixSE in forum General Tech Discussion
    Last Post: 06-06-2010, 08:20 AM
  2. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  3. some questions from a new guy
    By buster in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 02:25 PM
  4. Got some questions about my 97 GP SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 10-26-2009, 12:42 PM
  5. New guy with old questions I'm sure
    By bpm4x4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2009, 06:36 PM
