Thread: some questions from a new guy
Results 1 to 13 of 13
buster some questions from a new guy 01-19-2010, 03:56 PM
badbrad Re: some questions from a new... 01-19-2010, 04:02 PM
blowfishRus6 Re: some questions from a new... 01-19-2010, 04:13 PM
buster Re: some questions from a new... 01-25-2010, 03:24 PM
badbrad Re: some questions from a new... 01-27-2010, 10:15 PM
00gpgtp Re: some questions from a new... 01-28-2010, 04:40 PM
FlaminWhite97GTP Re: some questions from a new... 01-28-2010, 05:30 PM
Pittman06 Re: some questions from a new... 01-28-2010, 06:04 PM
00gpgtp Re: some questions from a new... 01-28-2010, 08:04 PM
buster Re: some questions from a new... 03-01-2010, 02:25 PM
badbrad Re: some questions from a new... 01-29-2010, 09:01 AM
gpgo Re: some questions from a new... 01-29-2010, 09:07 AM
badbrad Re: some questions from a new... 01-29-2010, 09:18 AM
  1. #1 some questions from a new guy
    Windsor Ontario
    I just bought my 97 GTP. Cheap car, hopefully will last a while. What are the weaknesses of these. I have a few problems, mostly electrical like no fog lights, sunroof won't move. What should I be watching for. I have never owned a car with a power adder. What are the easiest ways to get a few more horses?
  2. #2 Re: some questions from a new guy
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    friend, read the "safely modding your 3800" sticky please!
  3. #3 Re: some questions from a new guy
    Donating Users blowfishRus6's Avatar
    g.a.
    also read the KR stickey to get an idea of what blows these motors...
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: some questions from a new guy
    Windsor Ontario
    thanx,
  5. #5 Re: some questions from a new guy
    Dec 2008
    hueytown, alabama
    u read em yet????? do some searching on the forum, dig up old post to see. most of us have the same crappy problems.
  6. #6 Re: some questions from a new guy
    Jan 2009
    Michigan
    Quote Originally Posted by buster View Post
    transmission.
  7. #7 Re: some questions from a new guy
    SE Level Member FlaminWhite97GTP's Avatar
    Nov 2009
    Monee, IL
    ^Agree. Transmission can give you some problems, but if it was taken car if you should be fine for a while. Weaknesses mechanically, they are some. But the 3800 is a bulletbroof motor. Like badbrad said do some searching & look at the stickies & you will find what you need. Welcome to the forum BTW.
    Oh & with your sunroof, check you track & see if they are greased. If it not that, it could be a bad motor/gear. Fog light check your fuses & relays
    176K Miles, Things Done: 25K Tranny, VC & LIM Gaskets Replaced, synthetic fluids all around.
    Mods to come: CAI, Headers, Roller Rockers, U-bend & DP Delete, etc
  8. #8 Re: some questions from a new guy
    Wooster, Ohio
    Quote Originally Posted by FlaminWhite97GTP View Post
    It also couldn't hurt to check our fog light bulbs...
    Transmission, intake gaskets, water seal under the cowl on the pass side, window regulators, rockers rot off, strut mounts, both sway bars, oil pan gaskets, rack and pinion, and few others but those are the most common off the top of my head, and welcome!
  9. #9 Re: some questions from a new guy
    Jan 2009
    Michigan
    how many miles on the car?
  10. #10 Re: some questions from a new guy
    Windsor Ontario
    Quote Originally Posted by 00gpgtp View Post
    The car has 225,000 km (lol) about 180k miles
  11. #11 Re: some questions from a new guy
    Dec 2008
    hueytown, alabama
    pittman everythng u said was a problem i've had in mine. any car, u got problems happen. its good to know support is there if u need it. yeah man how many miles u got?
  12. #12 Re: some questions from a new guy
    Donating Users
    central ohio
    i have a 98 gtp with 152000 and no problems, my friend has a 98 gtp with 190000 and has only had to replace a waterpump. main thing is keep the maintenance up on them. trans fluid changes oil etc. they are really great cars if you dont overly abuse them.
  13. #13 Re: some questions from a new guy
    Dec 2008
    hueytown, alabama
    the intake gaskets are junk also. mainly because of the dexacrap coolant. mustangs are the same. i'd replace lim gaskets (if needed or unsure) and swap to the regular cheaper antifreeze, also clean out the coolant reservoir....a good tune or tuner will wake up the car and the trans setting are adjusted and make it much more driverfriendly and capable....i bought mine with 175k and now have 218k. new motor going together on the stand soon. o.p. leaks like a muthu. some replace the op gasket in car but i;ll wait and do new motor sometime.
  1. I have 2 questions.
    By jmj4492 in forum Off Topic Discussion
    Last Post: 09-01-2009, 09:56 PM
  2. I've got a few questions
    By josemolina2008 in forum General Tech Discussion
    Last Post: 08-23-2009, 09:55 PM
  3. a few questions
    By 04gtols1 in forum General Tech Discussion
    Last Post: 08-18-2009, 09:01 PM
  4. Car questions
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 07-18-2009, 12:01 AM
  5. 97 GT questions
    By spidamanSS in forum Off Topic Discussion
    Last Post: 07-23-2008, 09:27 PM
