Thread: Oil Pan Gasket Replacement
Results 1 to 13 of 13
  1. #1 Re: Oil Pan Gasket Replacement
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Remove the oil level sensor before removing the pan, it will prevent it from being damaged on the oil pickup tube while you are dropping the pan. It will leak oil if you crack the internal part.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  2. #2 Re: Oil Pan Gasket Replacement
    Oklahoma
    Quote Originally Posted by SlowFiero View Post
    Very good point.
  1. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  2. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  3. intercooler gasket information needed
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2008, 08:15 PM
  4. Head Gasket Company
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 04:32 PM
  5. Upper Gasket
    By TyroElite in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2007, 03:54 PM
