Thread: Lost Boost
Results 1 to 19 of 19
  1. #1 Lost Boost
    Well I hopped in my 2000 GTP to go to work and as I pulled out of the driveway I noticed the SES light on and I instantly saw that I wasn't boosting anymore. Drove fine besides the no boost on the way to work. Looks like I'll have to dig into it when I get off tonight. Was just looking for some common causes to help point me in the right direction so I can get it all working again ASAP.
  2. #2 Re: Lost Boost
    Tell us what code is set and that'll give the best help in diagnosis.
    Til then..it could be something simple like a bad BCA/BCS etc.
  3. #3 Re: Lost Boost
    I'd have to wait till I'm home to pull the code unless there is a key trick to get the code.
  4. #4 Re: Lost Boost
    We are willing to wait.
    See the code will probably enlighten us and save you time/money on the fix.
  5. #5 Re: Lost Boost
    I'll maybe try to run over to auto zone and have them pull the code to get a jump start on things. Is the BCS/BCA right on the supercharger? I have a second supercharger sitting in the back seat that I could yank parts off of............ I'm proficient with cars and engine work but I haven't done any engine work on the 3.8 yet.
  6. #6 Re: Lost Boost
    Pennsylvania
    Money's on "Front Bank Lean." Check the Rubber T under your s/c snout. It might be pulled off (they often dry rot and tear), causing a vacuum leak, which means that your MAP sensor won't see your boost and can't relay it to the computer, and therefore the DIC.
  7. #7 Re: Lost Boost
    Thanks. That's the type of info I'm looking for. Just common problems to give me a starting point.
  8. #8 Re: Lost Boost
    Yes, those are the parts on teh front of the charger.
  9. #9 Re: Lost Boost
    Alright....is there anything with the coupler/snout that could cause it not to spin the internals to cause no boost? Think that'd the worst case scenario right?
  10. #10 Re: Lost Boost
    If you have a belt, it's turnin.
    You have no boost and an SES light, car is complaining about something. See where I'm goin. There's little you can do w/o looking at the car.
  11. #11 Re: Lost Boost
    Well its all one belt I think (right?). No charging problems so I know the belt is intact. Looks like it must be vacuum/BCS/BCA related. Thats where I'll start looking once I can get out of work. Thanks again for the help pointing me in the most probable direction.
  12. #12 Re: Lost Boost
    Hmmm...guess I was wrong. The s/c belt is shredded.......
  13. #13 Re: Lost Boost
    One belt..uh no. Two belts. SC is by itself. Most likely you didn't hear the idler pulley going back and it seized up, then sent the belt into the abyss.
    Odd that you didn't hear any of that happening.
  14. #14 Re: Lost Boost
    Well....how easy should the super charger spin by hand? Guess the things to check is the idler pulley and the supercharger itself right?
    Maybe it broke last night right before I pulled into the driveway..i did have the stereo cranked.
  15. #15 Re: Lost Boost
    the blower should spin fairly easily, but you gotta realize youre spinning the weight of the rotors too so it wont spin for any considerable amount of time. to lock up the blower youd have to do something catastrophic.
  16. #16 Re: Lost Boost
    Check the pullies and you'll find that likely number 9 is fubared. You ask what is number 9 right? hang in ...I'll be back with da picture
    I'm back
    http://www.grandprixforums.net/commo...ets-39796.html
  17. #17 Re: Lost Boost
    You guys are good. Thanks get out of work in 1.5 hours and I'll be able to dig into this.
  18. #18 Re: Lost Boost
    I live here. TLSheff's Avatar
    Should it be number nine I have had the same thing happen. I still have the internals of what used to be a bearing in the #9 spot, the pulley.... dunno just disappeared. Never heard anything (radio was up enough to cover the wind noise @ 55mph with windows down), went to get onto highway and had no power at 3/4 throttle... quick check and no boost either, pulled over, pulley was gone and belt was kindly laid on the supercharger lol.
    Buy a Gatorback belt if you can find a store that sells them. Bill can probably supply the number for it, best belt by far. And check for the pulley, if its there still, spin it, if it has a rough spot at all it needs to be replaced. Odds are tho, itll be gone or really Fubar
  19. #19 Re: Lost Boost
    Pulley number 8 is no longer there..... Pulley 3 and 9 aren't in the best shape either so i think i'm going to replace them all right away.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  3. Boost lost at high speeds. Help?
    By pizzi22 in forum General Tech Discussion
    Last Post: 11-06-2009, 11:28 AM
  4. lost
    By allenscott292002 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 07:09 AM
