Thread: Header wrap on crossover?
Results 1 to 20 of 23
Agentlongwood Header wrap on crossover? 03-04-2011, 12:10 PM
Bio248 Re: Header wrap on crossover? 03-04-2011, 12:30 PM
Agentlongwood Re: Header wrap on crossover? 03-04-2011, 12:38 PM
Bio248 Re: Header wrap on crossover? 03-04-2011, 12:50 PM
Agentlongwood Re: Header wrap on crossover? 03-04-2011, 12:57 PM
Pure2sin Re: Header wrap on crossover? 03-04-2011, 01:04 PM
Bio248 Re: Header wrap on crossover? 03-04-2011, 01:04 PM
Dallasneon Re: Header wrap on crossover? 03-04-2011, 03:05 PM
SlowNA06 Re: Header wrap on crossover? 03-04-2011, 03:16 PM
Dallasneon Re: Header wrap on crossover? 03-04-2011, 03:24 PM
Silver GTP Re: Header wrap on crossover? 03-04-2011, 04:44 PM
SlowNA06 Re: Header wrap on crossover? 03-04-2011, 06:29 PM
Vegas~Blown Re: Header wrap on crossover? 03-06-2011, 11:46 AM
gtpsleeper Re: Header wrap on crossover? 03-04-2011, 04:58 PM
Bio248 Re: Header wrap on crossover? 03-04-2011, 04:59 PM
redlinepontiac Re: Header wrap on crossover? 03-06-2011, 12:26 PM
Dallasneon Re: Header wrap on crossover? 03-06-2011, 06:46 PM
charlieRobinson Re: Header wrap on crossover? 09-01-2015, 06:41 PM
SgtMarshal Re: Header wrap on crossover? 09-01-2015, 06:49 PM
coolone Re: Header wrap on crossover? 09-01-2015, 06:57 PM
EHB Re: Header wrap on crossover? 09-01-2015, 07:45 PM
SgtMarshal Re: Header wrap on crossover? 09-01-2015, 08:24 PM
bandook Re: Header wrap on crossover? 09-01-2015, 08:30 PM
  1. #1 Header wrap on crossover?
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    I saw a vid on youtube and noticed a guy had wrapped his exhaust crossover with header wrap. That sounds like a great idea to me since it sits right under the throttle body and seems very cheap lol. Just wanted to see if it was worth takin the 15 minutes to do it or if its just for show.
  2. #2 Re: Header wrap on crossover?
    for what? think logically how that would make any sort of difference on how the car runs.
  3. #3 Re: Header wrap on crossover?
    Nov 2009
    Orlando
    My thought was less heat radiating to the throttle body. Thats not the case?
  4. #4 Re: Header wrap on crossover?
    how long does the air sit in the throttle body to absorb heat?
  5. #5 Re: Header wrap on crossover?
    Nov 2009
    Orlando
    Gotcha. So then the heat shield ZZP sells for the TB is also kind of a waste right. Forgive my noobness but what does a TB spacer do. Is blocking off the coolant passage in the TB also a bit pointless or is that for something else?
  6. #6 Re: Header wrap on crossover?
    Minnesota
    I think the point is that unless you get an intercooler you are pretty much gonna have hot air any way you cut it. The spacer does nothing that you are going to see or feel and the coolant passages do nothing for cooling but do offer the advantage of being able to take the blower off without coolant leaking. If you think about where the air for the intake is coming from it is already hot.
  7. #7 Re: Header wrap on crossover?
    yes, the heat shield is a waste.
    the throttle body spacer just blocks the coolant ports and isolates it from the blower. also useless.
  8. #8 Re: Header wrap on crossover?
    Keller,TX
    If anything.......anything, good comes from wrapping the crossover it would be that it keeps the exhaust gases hot, which in turn keeps exhaust gas velocity up. But I doubt you would even get that out of just wrapping the crossover.
    Bio...thoughts?
  9. #9 Re: Header wrap on crossover?
    Pennsylvania
    If wrapping your headers will make horsepower, I will eat this table.
  10. #10 Re: Header wrap on crossover?
    Keller,TX
    I don't think anyone thinks you would increase power by wrapping headers. About the only thing I know its good for is retaining the heat within the exhaust pipe. Which may help with underhood temps.
    Its not gonna help the TB with incoming air due to the residence time of the air passing thru the TB. Like Bio said, its not there long enough to increase by any significant amount.
  11. #11 Re: Header wrap on crossover?
    Donating Users
    South Deerfield, MA
    Wrapping also keeps heat in the metal that your pipe is made of causing it to degrade faster. I did a lot of reading on this issue before I put my headers in and decided against any wrap.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  12. #12 Re: Header wrap on crossover?
    Pennsylvania
    Quote Originally Posted by Dallasneon View Post
    Lower temps would allow increased timing to create more ponies. But you wouldn't see lower under-hood temps. At all. So no ponies.
  13. #13 Re: Header wrap on crossover?
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    I wrapped my crossover because I had the stuff on-hand to do it --- it dropped the tb temp by about 20 degrees, not that it makes any difference mind you.
  14. #14 Re: Header wrap on crossover?
    the only reason wrapped headers are good is for exhaust systems that rapidly increase and decrease in temperature so they dont crack... my Nova is a dragster and i wrapped my headers for that reason alone...
    someone correct me if im wrong on that though its just from experience....
  15. #15 Re: Header wrap on crossover?
    wrap isnt going to help anything. it's an old school method that isnt necessary anymore with modern coating processes.
  16. #16 Re: Header wrap on crossover?
    Waukesha, WI
    headerwrap is useless on these cars, old school carbd car sure it makes a difference then.
  17. #17 Re: Header wrap on crossover?
    Keller,TX
    Quote Originally Posted by redlinepontiac View Post
    How does it make a difference on a carb'd car?
  18. #18 Re: Header wrap on crossover?
    SE Level Member charlieRobinson's Avatar
    May 2014
    OH
    my IATs are like 50 over ambient right now. I was thinking about wrapping just the crossover to try and keep the radiant heat from roasting my throttle body where my IAT sensor resides. Has anyone done this with good results?
    1999 Buick Riviera - L67
    PLX wideband +HPT pro +X-P HOT cam, 140#springs, 2x chain, LS7 lifted
    ZZP SS Headers + 3" Downpipe + 200 Cell Cat.+ Aero Resonator
    Gen V swapped L67, 60# injectors, E85, N*&LQ4MAF
  19. #19 Re: Header wrap on crossover?
    Kemmerer, Wyoming
    Quote Originally Posted by charlieRobinson View Post
    it makes no difference unless you have an amazing true cold air intake and an intercooler. the supercharger is going to heat the air up any.
  20. #20 Re: Header wrap on crossover?
    Nov 2011
    NY
    4 year old ghost thread... Nice!
  1. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  2. header wrap
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 11:36 AM
  3. Header Wrap?
    By DEC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2010, 03:20 PM
  4. Header wrap anybody ?
    Last Post: 06-26-2008, 06:29 PM
