Thread: Header wrap on crossover?
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Header wrap on crossover?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    if IAT'S have zero effect on anything , why did GM waste time and money to install IAT sensors ? ...
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  2. #22 Re: Header wrap on crossover?
    Kemmerer, Wyoming
    there is an IAT sensor because the temperature is always changing, and the pcm uses that data for stuff. having the headers wrapped isn't going to change the ambient air temp or the temp of the hot air going into the engine from the supercharger.
  3. #23 Re: Header wrap on crossover?
    Apr 2015
    Columbus, OH
    Have a look at the IAT timing tables and you will see how useless they are. The PCM will pull a degree or two of timing for temps that you will rarely see, unless drag racing a heat soaked engine in the desert. The PCM does not ADD timing if you make it super cool, only subtracts timing at extreme temps.
    Edit: my crossover is wrapped anyways. All the cool kids are doing it.
    Top Swapped 01 Imp
  1. header gasket - header clamps - kn filter
    By homerunhitter629 in forum General Tech Discussion
    Last Post: 02-21-2011, 10:00 AM
  2. header wrap
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 11:36 AM
  3. Header Wrap?
    By DEC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2010, 03:20 PM
  4. Header wrap anybody ?
    Last Post: 06-26-2008, 06:29 PM
