Thread: Out of curiosity EGR/IC Issues?
Results 1 to 13 of 13
  1. #1 Out of curiosity EGR/IC Issues?
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    I'm a ways from going IC'd but I was curious if anyone has had issues running an IC and retaining the EGR? I noticed how little time it takes to make this thing Filthy. That's got to affect airflow, or at least heat-exchanging efficiency of a core... Especially a nicer, more densely finned core. I have emissions in my area and that's why I ask. I may end up cheating and registering it in Wyoming with a PO box haha.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  2. #2 Re: Out of curiosity EGR/IC Issues?
    just take the EGR off. no reason to run dirty air through the core like that.
  3. #3 Re: Out of curiosity EGR/IC Issues?
    Arvada, Colorado
    I wouldn't run it that way but it won't pass an emissions inspection without EGR there. Could I gut it or something so it looks okay haha?
    Sig2
  4. #4 Re: Out of curiosity EGR/IC Issues?
  5. #5 Re: Out of curiosity EGR/IC Issues?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you can obviously pass obd2 with no EGR. Visual you can do block of plates and maybe pass if they dont get to involved. Most places just mirror the Cat though
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: Out of curiosity EGR/IC Issues?
    Arvada, Colorado
    Won't pass visual; OBDII isn't my concern... I live in Boulder County, as in Boulder, CO. Hippies run this county and they are sticklers... I mean like a mirror and flashlight in the engine bay. I'm fingers crossed on block-off plates.
    Sig2
  7. #7 Re: Out of curiosity EGR/IC Issues?
    Portland Oregon
    Hve someone with a tuner set your egr for some crazy high ect temp turn on. I know a guy that did that. Basically the computer waits for the engine to warm up to a certain temp to begin using the egr. With the temp set higher than the engine will ever see, you basically eliminated your egr while keeping it bolted up
  8. #8 Re: Out of curiosity EGR/IC Issues?
    Charles City, IA
    I just looked threw my bin in hptuners, I would not find any way to disable the egr in there. You can always just block the egr hole in the supercharger and leave it on with the flow codes deleted.
    SMGPFC Two Nipple General
  9. #9 Re: Out of curiosity EGR/IC Issues?
    ha............
    put the EGR in.
    have it tuned so it wont throw a code.
    run around with it unplugged.
    time for the test? plug it back in just before you get there.
    unplug after you leave.
  10. #10 Re: Out of curiosity EGR/IC Issues?
    Arvada, Colorado
    Fair enough. I don't think 20 minutes of recirculating the gunk will do too much harm.
    Thanks for the input, everyone.
    Sig2
  11. #11 Re: Out of curiosity EGR/IC Issues?
    just make sure its closed before you unplug it.
  12. #12 Re: Out of curiosity EGR/IC Issues?
    Jersey
    i deleted mine. passed visual and obd2
    16' wrx sti- stock
  13. #13 Re: Out of curiosity EGR/IC Issues?
    Go into HPT on teh first and front engine page is EGR diagnostics. Set the temp to 284 to keep the EGR from working. It's that easy.
    I had visual inspection here and left my EGR on the motor as well to pass. It was there, plugged in (they might notice if you unplug it, because it's right on top) and totally unfunctional. Heck..the core typically blocks the flow. Then tell the diags not to try and it never reports an issue.
  1. H.I.D Issues...need help?
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2011, 08:23 PM
  2. Odd abs issues
    By m1sterb0b in forum Brakes/Suspension/Chassis
    Last Post: 03-07-2011, 05:41 PM
  3. Out of sheer curiosity
    By leetaylor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2010, 07:18 PM
  4. A few issues
    By Ellen in forum General Tech Discussion
    Last Post: 09-17-2009, 09:29 AM
  5. HID issues
    By 99prixgt in forum General Tech Discussion
    Last Post: 12-25-2008, 12:27 PM
