Thread: Open cone intake clarification
Results 1 to 20 of 20
  1. #1 Re: Open cone intake clarification
    Pennsylvania
    Cone is a vast improvement over the drop-in filter.
    Flow test by ZZP on different size cones:
    227 CFM on 9" long 4" inlet clean K&N
    181 CFM
    on 7" long 3.5" inlet clean K&N
    As you can see, the 9x4 is what... a 22.5% improvement over the 7x3.5? and the 7x3.5 is easily an improvement over the stock setup.
  2. #2 Re: Open cone intake clarification
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    skip the 45* and find a 22.5* bend. less bends for more flow. pushes the filter toward the fender more too, not that it really helps.
    i got a 22.5* 4" elbow, the coupler and clamps from lowes for around $13.
  3. #3 Re: Open cone intake clarification
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Quote Originally Posted by oneil.GTP View Post
    Not that it much matters,
    According to SlowNA06, the 9" long 4" Dia filter is flowing 227CFM. If we assume that those values as correct, and are for redline RPM, then the 4" tube is flowing 3.78CFS which equates to 43.33ft/sec air speed. This is 29.54MPH air speed through the tube. A 45* elbow shouldn't be too restrictive given that speed.
    If I made another intake I would possibly use a 60* elbow instead of a 45* since it would point at the front headlight nicely. I think the 22.5* goes into the pit of the fender though, which is nice.
    I got bored and so decided to post this.
  4. #4 Re: Open cone intake clarification
    Pennsylvania
    ZZP's tests also indicate the following results before adding a filter:
    238 CFM on 5" of straight 4" Pipe
    220
    CFM on 26" of straight 4" Pipe
    183 CFM
    on 26" of straight 4" Pipe + 90* Bend
  1. Dyno Science: "CAI" Box vs Open Cone Intake
    By SlowNA06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2016, 12:29 PM
  2. open cone on an 04+
    By papaspanky in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 11:57 PM
  3. Open Cone Intake
    By demetriuslopez in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 11:11 AM
  4. how to put on a open cone
    By tssmokefangtp in forum General Tech Discussion
    Last Post: 11-01-2010, 10:27 PM
  5. Open cone intake
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-11-2010, 05:01 PM
