Thread: What is this and can I relocate it?
Results 1 to 8 of 8
  1. #1 What is this and can I relocate it?
    SE Level Member MyPrixGT06's Avatar
    Weirton, WV
    I just put an intake on my 2006 GT and found this in my airflow box.
    It looks like it needs to stay dry due to its location. Is there a way i can relocate it to be able to remove the rest of the filter box and where is a good location? And what is it for?
    Sorry about the poor quality picture.
  2. #2 Re: What is this and can I relocate it?
    GTP Level Member
    Pittsburgh
    That is your PCM, yes you can move it, and NO it doesnot need to be in a dry area. They are sealed from any moisture
    2003 SSEi,
  3. #3 Re: What is this and can I relocate it?
    if its the PCM you can just let it sit there where the stock air box was.
  4. #4 Re: What is this and can I relocate it?
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    if you want to get rid of the ugly sight from where the airbox is too but want to keep the tray just cut the top part of the box off. I did it and it works nicely keeps the PCM in place
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  5. #5 Re: What is this and can I relocate it?
    Weirton, WV
    I decided to take out the box and zip tie it so it won't move. I also but the soft side of velcrow to the underside of the PCM so if it does move it won't scretch anything up.
  6. #6 Re: What is this and can I relocate it?
    take the ribbed tubing off and replace it with a smooth AT LEAST 3" piece of pipe, 4" would be ideal. that is the restrictive part of the intake, not the air box.
  7. #7 Re: What is this and can I relocate it?
    Or just bolt the MAF to the TB...and then the cone to the end of the MAF...but I'd do what that guy^^ said.
  8. #8 Re: What is this and can I relocate it?
    Weirton, WV
    this was stage 1. First warm day since I got this car that I could play with it. I was planning on making a CAI and use pvc to run it to the fender. So I can go from TB and use a rubber fitting to connect the MAF and then pipe to cone?
  1. Relocate trunk open button
    By Wingsfreak9 in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2010, 02:37 PM
  2. IAT relocate?
    Last Post: 10-23-2008, 10:23 PM
  3. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
